Author Topic: td chip  (Read 3407 times)
raywilb
  • york. moved to Dalton , Thirsk
    • Citroen C4 Cactus
Re: td chip
« Reply #15 on: 02 August 2009, 19:37:55 »
after watching IanD resolder the battery holders to two key-fob circuit boards, hence getting each fob to work again in just a few minutes. iv,e every confidence in ian - my hat goes off to him.thanks once again.   ps.  also maplins are shortly opening a new store in york.   :y :y :y
Ian_D
  • York
Re: td chip
« Reply #16 on: 03 August 2009, 01:08:06 »
Anytime Ray! Like I said on the phone, worst case would be to make one good fob out of two duff ones. Was a bonus that we got them both fixed  :y
Mixed feelings about maplin... Yes it will be fantastic... but its one 1 mile up the road, so its too easy for me to nip in! It will become my second home  ;D and I will spend too much money there  ::)
[size=12]
Turk
  • Llanelli, Wales
    • 2.5td, H-D XL1200
Re: td chip
« Reply #17 on: 03 August 2009, 02:35:25 »
done my last one with a solder sucker & a fine point 40w iron, yes its fiddly & as TB says the 0v needs a bit more of a warm up but not too bad :y
I was a bit concerned about damaging the O/E chip, so didn't go too heavy with the heat.
Just as well, the O/E chip is back in for now, until I get my pump back from an overhaul.
The new chip was amplifying a fault with the pump. Still gave a significant increase in power and MPG but the pump issue was causing a judder between 1500 to 2000 rpm.
Fitted a 2nd hand pump but that too has a fault. It's not too bad with the O/E chip fitted, so the only time the car is off the road is a few hours whilst I'm refitting the pump.
Getting a bit impatient now, but I'm getting a good deal on the pump overhaul price, so can't complain really, and it's not as if the car is off the road.
I'm like a kid on crimbo eve, waiting for Santa to call.  :D
