Author Topic: td chip  (Read 3380 times)
raywilb
  • york. moved to Dalton , Thirsk
    • Citroen C4 Cactus
td chip
« on: 29 July 2009, 14:43:14 »
a lots been said re td chipping. can anybody please tell me roughly the cost of this procedure .
Pitchfork
  • Tadley (near Basingrad)
  • Barndances & Morris
Re: td chip
« Reply #1 on: 29 July 2009, 14:58:22 »
Don't even contemplate it if you have an automatic unless you are prepared to replace the gearbox with an AR35 from a 3 litre V6
unlucky alf
  • worksop, notts
Re: td chip
« Reply #2 on: 29 July 2009, 14:58:48 »
my chip was somewhere around the £80 mark but that was a while ago, plus mine just plugged in so no soldering of a socket adapter like some of the later TD`s ;) of course that doesnt include the AR35 g/box if youve got an auto.
raywilb
    • Citroen C4 Cactus
Re: td chip
« Reply #3 on: 29 July 2009, 15:06:38 »
its a manual  :y :y
unlucky alf
  • worksop, notts
Re: td chip
« Reply #4 on: 29 July 2009, 16:56:05 »
its a manual  :y :y
in which case get hold of TB & he will get the price etc for you if you ask nicely :y
Ian_D
  • York
Re: td chip
« Reply #5 on: 29 July 2009, 22:35:35 »
Take it the chip is the next thing to fit then Ray!   :)
Good choice!  :y
What ECU is he likely to have? Its S reg I think.  ::)
If its not got the socket, how may pins is it? I take it its a DIP?
Anyway, Get one ordered regardless Ray, we will cross the bridge when we get to it regarding the fitting! :D :D :D
[size=12]
Turk
  • Llanelli, Wales
    • 2.5td, H-D XL1200
Re: td chip
« Reply #6 on: 30 July 2009, 01:06:43 »
You'll need the 3 figure number off the actual ECU.  :y
I think it's an 18 pin. Fingers crossed it's already a plug-in jobbie.
Mine wasn't and de-soldering was a right old fiddle, but well worth it.  :y
raywilb
    • Citroen C4 Cactus
Re: td chip
« Reply #7 on: 30 July 2009, 15:09:59 »
just toying with the idea ian. since you fitted the hotfix jobbie for me, mpg has gone up ever so slightly
not sure if there is a connection. but i,m still not getting 40 + on a run as i believe i should be.  :y
Pitchfork
Re: td chip
« Reply #8 on: 30 July 2009, 15:15:39 »
Get a solder sucker from Maplin - they're not expensive & it will be easy
Turk
  • Llanelli, Wales
    • 2.5td, H-D XL1200
Re: td chip
« Reply #9 on: 30 July 2009, 21:53:51 »
Nope. Still to fiddly, even for the smallest sucker.
Used de-soldering wick. Took a good two hours to get the original chip out and solder in the socket.
Ian_D
  • York
Re: td chip
« Reply #10 on: 31 July 2009, 00:36:18 »
2 hrs seems a bit OTT?
Did you forget to plug the soldering iron in?  ;D ;D
[size=12]
Turk
  • Llanelli, Wales
    • 2.5td, H-D XL1200
Re: td chip
« Reply #11 on: 31 July 2009, 13:44:05 »
Yep, two hours from start to finish.  ::)
Not a hope with any of the solder suckers and the de-solder wick would only work by adding fresh solder to the joint otherwise it wasn't removing the solder completely.
Re: td chip
« Reply #12 on: 31 July 2009, 14:42:15 »
Amateur  ;D ;D :y
It can be done with a solder sucker....the secret is in the iron and bit selection (most low wattage Maplin type irons wont do it!)!
Re: td chip
« Reply #13 on: 31 July 2009, 15:33:24 »
Its easy enough with right equipment.  Its through plated, so harder than single sided stuff, and the 0v pin needs a decent iron.
unlucky alf
  • worksop, notts
Re: td chip
« Reply #14 on: 31 July 2009, 19:16:25 »
done my last one with a solder sucker & a fine point 40w iron, yes its fiddly & as TB says the 0v needs a bit more of a warm up but not too bad :y
