Author Topic: Help with IE8 pls  (Read 1997 times)
Taxi_Driver
Help with IE8 pls
« on: 02 August 2009, 19:36:50 »
Ok....so i have my new toy....a netbook  :)
Ive put IE8 on it, but it doesnt want to log on as TD when i come onto OOF, automatically, I have to logon each time.
I thought it was a cookies issue, but ive tried lowering the privacy setting to 'accept all cookies' but it still doesnt want to play ball.
Its probably a silly setting, i havent found yet, so i thought id ask.....other IE8 users....have you had the same prob?  :-/
Only other thing to mention, is that since using IE8, when i do logon to OOF, i get the spoofing error message that i seen others mention.....never had that warning before using IE7.
« Last Edit: 02 August 2009, 19:37:36 by Taxi_Driver »
Martin_1962
Re: Help with IE8 pls
« Reply #1 on: 02 August 2009, 19:42:26 »
It forced me to accept that I needed to move to Firefox - so I did
« Reply #2 on: 02 August 2009, 19:54:14 »
I get that too mate, well happens on one of the laptops not on the desktop or other lappy.
Taxi_Driver
« Reply #3 on: 02 August 2009, 19:59:11 »
Just discovered.....at the moment its only happening on OOF......other forums that require username and password work fine for me.....ie close the IE tab....reopen it....goto the site...and im logged straight back in automatically  :-/
Welung666
« Reply #4 on: 02 August 2009, 20:00:51 »
Have you added OOF to the compatability list?
Taxi_Driver
« Reply #5 on: 02 August 2009, 20:08:37 »
Just tried your suggestion m8.....
omegaowners.com is now the only entry....
Closed the tab....opened a new one...and still had to log back on manually  :(
So unless you have to restart IE, it didnt work  :(
Welung666
« Reply #6 on: 02 August 2009, 20:10:29 »
Worth a try, it's how I solved the problems I had on Windows 7 RC1 and IE8 using OOF.
« Reply #7 on: 02 August 2009, 20:18:50 »
Other than occasional rendering issues, I've had no hassle with IE8, and I use it with OOF
Taxi_Driver
« Reply #8 on: 02 August 2009, 20:19:21 »
Just restarted IE.....no difference  :(
Taxi_Driver
« Reply #9 on: 02 August 2009, 20:21:52 »
Any idea why, everytime i log in, manually, i get a spoofing message?
« Reply #10 on: 02 August 2009, 20:26:01 »
Just delete your cookies again
Also, are you using your own home broadband?
Taxi_Driver
« Reply #11 on: 02 August 2009, 20:44:12 »
Tried deleting cookies, no difference  :(
Yes i am connected using my ISP connection, just checked the router, same IP addy it has as the warning message....
Checked the router coz i do have a voda USB broadband stick.....which was connected earlier today, but isnt now.....and def the warning is the IP im connected to now.....which my home connection
Taxi_Driver
« Reply #12 on: 03 August 2009, 09:54:47 »
Ive found the answer...
If i use www.omegaowners.com , then i have login manually and then get the spoofing message...
If i use www.omegaowners.com/forum/yabb.pl......
then i get logged in automatically and no error message  :y
semisheen
  • Chesterfield
« Reply #13 on: 03 August 2009, 19:02:50 »
Do you log outy of OOF ...if you dont oof will remember your IP and when you log back in using www.omegaowners.com...it basically sees somone else trying to log in with the sdame IP adress ...if you use www.omegaowners.com/yabb.pl......whateaver it will see your previous session and oof will know who you are ....Hope that makes sence ?  :y
« Reply #14 on: 03 August 2009, 19:08:57 »
Can't explain why it does that...
