Author Topic: X box experts ?  (Read 1615 times)
X box experts ?
« on: 25 August 2009, 17:26:04 »
My daughter gave me her x box to fix ,dads can fix everything apparently.The disc drive wouldnt open ,I dismantled it and had a fiddle with the mechanism, put it back together and hey presto it now works fine.Trouble is all 4 red segments are flashing.I know this is not good, but what have I done  :question ::) :o
Welung666
Re: X box experts ?
« Reply #1 on: 25 August 2009, 17:30:34 »
Google for 'Red ring of death' !!!
Re: X box experts ?
« Reply #2 on: 25 August 2009, 17:46:20 »
They all seem to talk about up to 3 red lights.I ve got 4 :o :'(
waspy
Re: X box experts ?
« Reply #3 on: 25 August 2009, 17:58:45 »
How old is the xbox?
Re: X box experts ?
« Reply #4 on: 25 August 2009, 18:01:53 »
I think its just over three years. :(
waspy
Re: X box experts ?
« Reply #5 on: 25 August 2009, 18:04:02 »
Not so bad then, at least you've not voided your warranty.
Have you checked all the connections internaly?
You may have disturbed some thing ;)
Re: X box experts ?
« Reply #6 on: 25 August 2009, 18:06:17 »
yup, everything looks ok.although what I know about electrickery could be written several times on the back of a stamp. ;D
Re: X box experts ?
« Reply #7 on: 25 August 2009, 18:18:38 »
YAY.....just fixed it.
Microsoft site says this problem may be caused by AV cable not being connected properly.
It didnt have one connected at all. ;D ;D
Plugged everything in and it works fine,told you I knew all about this kind of thing didnt I. :y :D ;D
Re: X box experts ?
« Reply #8 on: 25 August 2009, 18:20:44 »
Result :y :y
waspy
Re: X box experts ?
« Reply #9 on: 25 August 2009, 18:22:28 »
I did just the same a while back :-[
Nice one matey :y :y :y :y
Re: X box experts ?
« Reply #10 on: 25 August 2009, 18:24:38 »
Daughter wil be pleased.Bought the son a brand new one for his birthday last week as his had packed up.might try to fix the old one now,and then flog it. :)
KillerWatt
Re: X box experts ?
« Reply #11 on: 25 August 2009, 19:03:14 »
Buy yourself an X-Clamp kit, it isn't going to work for much longer before you get the 3 red lights.
Re: X box experts ?
« Reply #12 on: 25 August 2009, 19:04:16 »
wots that then? :-/ :)
KillerWatt
Re: X box experts ?
« Reply #13 on: 25 August 2009, 19:13:41 »
The 3 red lights is GPU (Graphics Processing Unit) failure.
What actually happens is that the (surface mounted) GPU comes away from the mainboard when the heat builds up (the GPU goes "dry joint")
The modded X-Clamp doesn't cure the actual reason for the fault occuring (the mainboard ends up being "flexed" when the console is assembled), but it helps to alleviate it by quite a margin.
Re: X box experts ?
« Reply #14 on: 25 August 2009, 19:30:54 »
will look into it thanks.this one doesnt get used much but my son is on his 3rd one.Had it replaced by MS once but that one just produces a frozen screen as soon as its switched on now.
no red lights etc,so bought him a new one,but if its possible to fix the broken one might flog it and get some dosh back.
