Author Topic: Leaving the site (Not Totally)  (Read 5549 times)
nixoro
  • Hitchin, Herts
« on: 28 February 2007, 10:14:01 »
Well today is the last day of me having constant access to the site via work.
Well I say that the new job may have its benefits.
Not having access at home will prove a pain so will eventually be getting online at home.
I would like to thank all for any help given to me over the time I have been on here.
I will be online today but after 6 I will be logging on as and when I can.
So to all Good Luck with your Omega's :y
bob.dent
  • Hertfordshire
  • Drives better than an Omega
    • Mondeo 2.0TDCI Estate
Re: Leaving the site (Not Totally)
« Reply #1 on: 28 February 2007, 10:34:25 »
......so this is not goodbye, just au revoir. ;)
Good luck with the new job Roy, I'm sure you'll be posting regularly again soon. :y :)
nixoro
  • Hitchin, Herts
« Reply #2 on: 28 February 2007, 10:43:57 »
Cheers Bob :y
« Reply #3 on: 28 February 2007, 11:18:21 »
Good luck Roy and dont leave it to long ;)
nixoro
  • Hitchin, Herts
« Reply #4 on: 28 February 2007, 11:24:21 »
Cheers Pete, I dont think it will be too long, even the misses wants the internet now.
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
« Reply #5 on: 28 February 2007, 11:58:24 »
Best of luck with the new job :y
I like red cars
nixoro
  • Hitchin, Herts
« Reply #6 on: 28 February 2007, 12:02:10 »
Cheers Auto Addict :y
Martin_1962
« Reply #7 on: 28 February 2007, 12:07:57 »
See you soon (we hope)
nixoro
  • Hitchin, Herts
« Reply #8 on: 28 February 2007, 12:12:17 »
Cheers Martin :y
RossPhim
  • Morayshire, Scotland
  • The blue oval now-a-days!?!
    • 2.2 TDCi TXS
« Reply #9 on: 28 February 2007, 14:17:47 »
All the best dude.
This may be the chance I need to catch you on post count ....... but I doubt it!  ;D
Take care. :y
The Barge Captain
« Reply #10 on: 28 February 2007, 14:19:10 »
Good luck mate.  See you around.
nixoro
  • Hitchin, Herts
« Reply #11 on: 28 February 2007, 15:11:55 »
All the best dude.
Take care. :y
Ross, good luck with the posting :y
Cheers guys hoping to get the internet at home its sods law though i can only get 512K but thats the trouble with living too far from the exchange
« Last Edit: 28 February 2007, 15:14:27 by nixoro »
    • E250 Est / Elroq
« Reply #12 on: 28 February 2007, 15:20:28 »
All the best dude.
Take care. :y
Good luck
Dont give up on 1 meg, do you know your line figures?
I left demon as they refused to try and upgrade me to 1 meg
I knew neighbours had faster
Moved to zen who previously confirmed they would try, they succeeded, although my line is dead on the limits, it is stable enough.
nixoro
  • Hitchin, Herts
« Reply #13 on: 28 February 2007, 15:28:35 »
All the best dude.
Take care. :y
Good luck
Cheers Jimbob
If your meaning line rates 1meg, 2meg, 8meg then 512k max according to BT for me.
Shall try different providers though.
« Last Edit: 28 February 2007, 15:29:39 by nixoro »
    • E250 Est / Elroq
« Reply #14 on: 28 February 2007, 15:38:29 »
No, they are BT guesstimates
real figures attainable from some routers, Signal to noise and attenuation.
my Att is 58.5 - just under the max possible for 1 meg
my S2N is 14.5, not quite so important
fyi, from thinkbroadband.com
    *   Line Length
      (They need to know how far you are from the exchange), you must be within ~3.5km to pass for the 2Mbps product, and within approximately 6km for the 1Mbps ADSL products. There is no set limit for a 0.5Mbps service, all but 0.2% of lines should support a 0.5Mbps service.NB: This is related to the length of the line rather than the physical distance from the exchange.
    * Line Loss
      (They need to ensure your line has suitable quality for ADSL), You need a line loss of no more than 43db for the 2Mbps product, 60dB for 1Mbps product. This test is normally a paper exercise based around the records for your line and area, if a border line figure appears they may test it out in the street. No limit exists for 0.5Mbps services, if you are connected to an enabled exchange your line will be enabled and if it does not work an engineer visit will be arranged to try and get you a service.
      Before 6th September 2004, the limits were 41dB on both 1Mbps & 2Mbps products, and 60dB for 0.5Mbps. Additionally before 24th September 2003, the 512kbps line loss limit was 55dB.
    * Capacitance
      (Again, this is to establish line quality), to pass, this should be below 160nF - for RADSL the figure is believed to be 300nF (nF is nano-farods).
    * APTS
      This test uses special software on the engineers hardware to talk to the DSLAM and measure the attenuation across the actual line. The limits using this kit are 43dB for a 2Mbps service, and 60dB for the 1Mbps service. Currently this is the definitive test, with 0.5Mbps it is a case of so long as your modem will work you can have the service.
    * Woosh Attentuation Test
      The woosh test is actual a whole suite of tests, the attenuation measurements are just one subset. This is not used for line qualification anymore, due to the variations caused by the various bits of ADSL hardware people use.
      The woosh attenuation test looks at the quality of the line across the DSL frequency range and measures how much of the signal reaches your house, the lose should be less than 45db for 2Mbps and 64dB for 1Mbps products. ISPs have the ability via the ECO interface to remotely do this test, but a pass with this test does not guarantee acceptance onto the 1Mbps and 2Mbps limits.
      Many ADSL modems will display the equivalent of the woosh test, but these can be inaccurate. Some modems can be as much as 20dB, though the majority are within 2-3dB. For those with very long lines, the Signal to Noise ratio (Noise Margin) becomes critical, ideally a figure above 6dB is needed for most ADSL kit to function.
