Author Topic: mobo reliability vs temperature..  (Read 1400 times)
Re: mobo reliability vs temperature..
« Reply #15 on: 29 August 2009, 22:54:05 »
Glad all those fans sorted it cem - otherwise you would be trying the overclockers liquid nitriogen route  :) :) ;)
Dontgo giving him any idea's   ;D ;D
 ;D
yep..for a short time this came to my mind but even a new mobo with  better cooling frames and temperature range would be a cheaper solution..
have tried some expensive cooling systems years ago when overclocking was my favorite..
eddie
  • Cardiff
« Reply #16 on: 30 August 2009, 00:02:50 »
Are you able to monitor your CPU's speed?  I have 2 monitors on both cores and 90% of the time they only run at 50% (1.4 Ghz),and very rarely do they both go to max. (2.7Ghz).  Maybe you have the power save feature turned off ?
eddie
« Reply #17 on: 30 August 2009, 08:44:40 »
How many PC's do you have in the command centre then Cem.   ::) :y
« Reply #18 on: 30 August 2009, 09:04:28 »
eddie
Edie you are right, power save feature turned off.. I hate lazy pcs  ;D :y
« Reply #19 on: 30 August 2009, 09:08:17 »
three.. 2 core duo , 1 p4..
