Author Topic: Power Cut Info  (Read 2167 times)
Power Cut Info
« on: 03 September 2009, 14:55:51 »
Have had 4 power cut since I move in June, 2 of which were last night.
Does anyone know of any sites where I can gain info on these cuts.
I am I South Yorkhire,  Should be with Npower but sadly have E-On at the moment (Long Story)
I did get some info on the phone and told it was a WAN problem, so assuming that means a Wide Area Network problem there must be internet info available.
TIA.   :y
Also after info regards sub stations and Power stations that actually supplymy power.
« Last Edit: 03 September 2009, 14:56:48 by skruntie »
Debs.
Re: Power Cut Info
« Reply #1 on: 03 September 2009, 15:06:19 »
TIA.   :y
It`s a regular thing here in the hilly-bits of Wales; `power`s 'on and off like a Jewish wedding!' ;D
I bought a UPS (though `not a very good one) to try and alleviate the inconvenience of lost data and damaged computers. ::)
I did complain to my R.E.C (Scottish Power) but they cited T & C`s not promising absolute continuity of supply, only to supply power within 'standards' when there! :-?
Re: Power Cut Info
« Reply #2 on: 03 September 2009, 15:10:18 »
Not aware of any, they do achieve a 6 9's availability of supply though!
kris
  • manchester
Re: Power Cut Info
« Reply #3 on: 03 September 2009, 15:52:37 »
Re: Power Cut Info
« Reply #4 on: 03 September 2009, 16:23:56 »
Mr Skruntie I invite you to come here.. and live in a  mountain village.. clean air, natural food, animals and so on..
and you will never have problem with power cut because you wil not have electricity ;D ;D
« Last Edit: 03 September 2009, 16:24:14 by cem_devecioglu »
Re: Power Cut Info
« Reply #5 on: 04 September 2009, 01:30:14 »
Sounds good to me, but what are the ladie's like.   ::)
« Last Edit: 04 September 2009, 01:30:34 by skruntie »
Re: Power Cut Info
« Reply #6 on: 04 September 2009, 09:38:04 »
erm.. all faces and hands a bit fractured from work and sun.. rarely you will see someone fat.. but surely none of them looks like perfect factory production  ;D :y
Re: Power Cut Info
« Reply #7 on: 04 September 2009, 11:58:52 »
have a look here mate
http://www.eon-uk.com/distribution/powercuthistorypostcode.aspx
PMSL
4 power cuts and yet no history them.  Sounds right to me.
Cheers for the link.
miked
  • North Yorkshire
Re: Power Cut Info
« Reply #8 on: 04 September 2009, 14:11:23 »
Also after info regards sub stations and Power stations that actually supply my power.
There will be a number of sub stations involved, reducing from the 400KV super grid down to 415V three phase within your street.  Your house will be fed from one of the three phases (240V between phase and neutral).  Your power cuts will be as a result of a fault developing within one of these sub stations, probably the smaller local one in your area.
As for which power station your electricity comes from, really its impossible to say.  The national grid transmission system covers the UK with all generators connected to the grid.  Electricity is generated on-demand so say you switch your kettle on, the total demand goes up by 1 'kettles worth', all the generating Units selected to frequency response (mainly coal fired units as nuclear and gas turbine plant is very inflexible) see a slight increase in demand and generate a little bit more electricity to keep the system frequency at or around 50Hz.  So your kettles worth of electricity might come from Longannet in Scotland (coal), Dinorwig in Wales (Hydro), Drax, Ferrybridge or Eggborough in Yorkshire (Coal), Ratcliffe where they are going to invade in October (coal), Tilbury near London (Coal) etc etc
miked
  • North Yorkshire
Re: Power Cut Info
« Reply #9 on: 05 September 2009, 23:19:48 »
Why the ???
Fairly straight forward?
Re: Power Cut Info
« Reply #10 on: 05 September 2009, 23:34:15 »
I understood it.   :y :y
Re: Power Cut Info
« Reply #11 on: 05 September 2009, 23:39:32 »
I thought miked's piece was quite plain although I can't understand this post :-? :-?
Re: Power Cut Info
« Reply #12 on: 05 September 2009, 23:43:30 »
Neither could I but didnt want to comment.
Ratty
  • Coventry
    • '99 2.5 CDX Mini-FL Est
Re: Power Cut Info
« Reply #13 on: 05 September 2009, 23:48:24 »
I think his post is rather questionable...
OK, I'll get me coat...
John
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
Re: Power Cut Info
« Reply #14 on: 06 September 2009, 17:10:00 »
Why the ???
He's trying to get his post count up to sell a car.
Most of his posts have had similar content.
TuBy's new whipping boy.
