Author Topic: mains leads in eu  (Read 1185 times)
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
mains leads in eu
« on: 06 September 2009, 21:16:58 »
the blue camping mains leads we have here in the uk, would this be the same plug in france or is there a converter?. thanks. jon. :y
Re: mains leads in eu
« Reply #1 on: 06 September 2009, 21:24:28 »
from memory, same connector, though a lot are only 6A iirc
« Reply #2 on: 06 September 2009, 21:27:14 »
Might be worth adding a shuko adaptor to your collection just in case. IIRC, that's what we had in Italy. Not that we brought any electrical items to plug in.
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
« Reply #3 on: 06 September 2009, 21:29:12 »
Is this a confession?  ::) ::) ::)
kris
  • manchester
« Reply #4 on: 06 September 2009, 21:30:41 »
sounds like it to me  ;D ;D ;D ;D
The Red Baron
« Reply #5 on: 06 September 2009, 21:44:03 »
thanks tb & kevin. :y
Gaffers
« Reply #6 on: 06 September 2009, 22:10:04 »
Not even a little bite... ::) ::) ::)
« Reply #7 on: 06 September 2009, 22:13:19 »
Newer/more modern sites use the same "blue plug" as UK ... older and most "Camping Municipal" sites use the French 2 pin
you can get adapters from most accessory shops .. or from here ..
http://www.camperlands.co.uk/store/erol.html#11193x0
go to "Mains hookup cables and Adapters" then on the next page, bottom row on the left "Continental Plug to caravan convertor"  .. £4.50
As a matter of interest ... I carry 2 of those .. one has been rewired to swap the live & neutral over.
French don't bother about polarity as everything is double pole switched, but we only switch one , so reverse polarity can be a problem, by having a pre-wired reversed cable .. if I get a plinth that is reverse wired I use the "modified" adaptor and all ends up where it should be !!!
HTH
« Last Edit: 06 September 2009, 22:18:55 by entwood »
The Red Baron
« Reply #8 on: 06 September 2009, 22:15:57 »
i fear not.
The Red Baron
« Reply #9 on: 06 September 2009, 22:20:47 »
thanks for that entwood.  :y
« Reply #10 on: 06 September 2009, 22:27:34 »
Welcome mate   :y :y :y
If you don't have one, this is all you need to check polarity, dead simple to use...
http://www.discount-towing.co.uk/product/545-Mains_Polarity_Tester_Plug
again .. most accessory shops stock them.
« Reply #11 on: 06 September 2009, 22:42:37 »
Ahh, yes. Very handy bit of kit whenever you have to trust someone else's wiring. :y
Page created in 0.028 seconds with 16 queries.
