Must Have's from ALDI
Started by Auto Addict, 26 February 2007, 17:55:21
That air compressor has a good air output (9.5CFM) but a small tank so a reasonable hobby unit at an excellent price....
QuoteThat air compressor has a good air output (9.5CFM) but a small tank so a reasonable hobby unit at an excellent price....
Looks same as mine, only mine was less than £50...
Might get the air hammer if anyone thinks its any good....
Auto Addict
Well it's cheap enough, and carry's a 3 year warranty.
I like red cars
Ken T
I'm a bit puzzled by the compressor numbers. 1HP is 746watts, so 1.5Kw means only 2.01HP. Where do they get the 2.5HP from?. It looks very small to give that output. :-?
Can't argue with the physics. Something doesn't add up. 1.5kw will be the motor input power as well, so it will have under 2HP output due to inefficiencies in the motor.
QuoteCan't argue with the physics. Something doesn't add up. 1.5kw will be the motor input power as well, so it will have under 2HP output due to inefficiencies in the motor.
Looks identical to mine physically, but badged different.  Mine is 2hp according to box...
Are they quoting Watts or VA.........or is it a typo....the air displacement sudgests 2-3Hp...
Ken T
It might be a typo for the HP. Still at 1.5KW it sounds quite good. I don't think you could buy an electric motor for £60!. Wonder what its like paint spraying?
Martin_1962
I am tempted by the compresor as I have to respray my bumper and my spoiler
sir moanalot
looks like a couple of bargains to add to the tool collection, always worth keeping an eye out in aldis's.
Big Rod
Found out about these on Sunday.
I'll be going straight up there first thing on Thursday!!  8-)
If I have to explain you won't understand!
QuoteIt might be a typo for the HP. Still at 1.5KW it sounds quite good. I don't think you could buy an electric motor for £60!. Wonder what its like paint spraying?
Single panels would be fine....a whole side of a car would be pushing it as the reservoir is a bit small......you could always couple up an empty propane cylidner to use as an extra reservoir.....and you need an air filter for spraying.....
Auto Addict
Well, I think I'm going to buy them, if I only end up inflating tyres, and undoing wheel nuts with them.
I like red cars
Markie
i'm tempted
Good deal then .... :-/
Will they really remove very stubborn wheel bolds? I've broken two sockets removing the wifes... :'(
