Camshafts...found this out
Started by Essex_Andy, 03 March 2007, 23:22:42
Essex_Andy
Well under the influence of mr jack daniels I got bored and surfed the net
And for the 2.5 V6...stock 3.0 cams offer better lift than fast road 2.5 cams
stock 3.0 offer 10.00mm lift v 9.53mm lift for fast road 2.5 kent items
And kent want circa £400 for a set
If an artic overtakes you, you're driving too slow!!!!!!!!!!!
hotel21
#1
Good find....
Confirms that the cams from a 3 litre when installed in the 2.5 is a good deal.
Even allowing for a few thou' miles wear on the doner cams.....   :y
and the BHP is only very slightly reduced in comparison.
HtH
B
ps - and instead of Mr Jack, its a rather tasty refugee from my last French trip to the vinyards.  Glad I had a second bottle and she is away to bed.   ;)
QuoteEven allowing for a few thou' miles wear on the doner cams.....   :y
Which wont make a blind bit of difference thanks to the followers which maintain a constant load on the cams and hence wear the entire surface at a fairly constant rate which maintains the profile......that and the fact that these cams dont seem to wear....
