Author Topic: MOT blues  (Read 1104 times)
omegod
  • liverpool
    • 2017 Seat Ateca
MOT blues
« on: 26 September 2009, 11:19:47 »
Well sadly she has failed on a couple of bits:
Rear exhaust not adequately supported, easily sorted
Nearside rear brake pipe excessively corroded
Front to rear brake pipe excessively corroded
Exhaust emissions Lambda reading after 2nd fast idle outside specified limits! reading was 1.11 then 1.07 against a limit of 1.03
Brake pipes will be made up by the local factors but the emissions im not sure of so any advice welcomed!
Welung666
Re: MOT blues
« Reply #1 on: 26 September 2009, 11:22:11 »
Get it warm and give it an Italian tune up ;)
Re: MOT blues
« Reply #2 on: 26 September 2009, 11:52:16 »
Disappointing news O, hope you get it sorted without too much difficulty. :y :y
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
Re: MOT blues
« Reply #3 on: 26 September 2009, 12:29:55 »
'Italian Tune-up' then straight onto the emissions tester.
omegod
  • liverpool
    • 2017 Seat Ateca
Re: MOT blues
« Reply #4 on: 26 September 2009, 12:50:57 »
just been under and there is some surface corrosion on the brake pipes but doesn't seem too bad and could clean up, really don't fancy replacing the front to back due to the complex bends, dismantling and so on. Any idea what would be a supply and fit price for this would be????
Exhaust was just the rubber had slipped off.
Found a small split on the ICV pipe and wondering if this would affect the emissions???
