Pages: 1 2 [3]  All   Go Down
Author Topic: Block paving.  (Read 4332 times)
Re: Block paving.
« Reply #30 on: 28 September 2009, 16:06:34 »
i,m a brickie by trade, but i did literally 1000 sq mtrs during the 90,s when the Berlin wall came down. ( bus stations , lorry parks etc ) and i agree its all about the prep. wacker plate heavier the better a good tip is stand on the finished screed - you should not leave a footprint , also wet sand is no good.
The weight of the wacker has no bearing on it at all (a very common myth), its actually based on the impact force per m2. Hence a smaller plate compactor with a small base can have a much higher impact force then a larger item with a big plate. In this case, the smaller one will give greater compaction and give better results.  :y (Studied this in great details before purchasing one  :D)
My finished base took the weight of the rear wheels of a tipper which was dropping another 10 tons of base!  :o (Which I was pretty surprised by)
Re: Block paving.
« Reply #31 on: 28 September 2009, 16:46:37 »
12 stone bloke stands on your foot it hurts.
6 stone woman in stiletoes daintily steps on your foot (with the heel) is a killer.  Doesnt arf make yer eyes water.  :'( :'( :'(
raywilb
  • york. moved to Dalton , Thirsk
    • Citroen C4 Cactus
Re: Block paving.
« Reply #32 on: 28 September 2009, 17:15:34 »
the problem small plates can cause in my experience is when turning they can move sand which has just been wackered. i prefer one with a reverse. we did bases that had to take 40 tons +
Pages: 1 2 [3]  All   Go Up
