Author Topic: VHF MARINE HAND HELD RADIO  (Read 2806 times)
Tony H
  • liverpool
  • Black Elites are luurvley
« on: 04 November 2009, 20:49:46 »
Hi everyone. Can any one tell me what sort of amp output charge level my hand held radio would require I bought it second hand but it didn't have a charger with it.
It's a Silva S12
The spec is: operating voltage 8.4 v DC
Max charge voltage                 13 V
RF output                                4W (High power)
                                               1W (Low power)
TIA
Tony
Plomien
  • Swansea
    • Landrover Freelander TD4
Re: VHF MARINE HAND HELD RADIO
« Reply #2 on: 04 November 2009, 21:31:02 »
There you go, 1.2A and throw in 20% extra for good measure (and cheap naff supplies!)
rob in gib
  • Plymouth
    • Jaguar S type 3.0
« Reply #3 on: 04 November 2009, 22:10:56 »
Just chilling in the sun. I wish back in the rain like everybody else
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #4 on: 04 November 2009, 22:16:04 »
Disagree, the 1.2A is the current drain from the battery when transmitting on High Power. The Battery is rated at 650mA so charging it at 1.2A isn’t going to do it any good.
If charge current is unknown, safe rule of thumb is to slow charge at 10 - 20% of the batteries output rating.
Noticed that the Hand Held has a 12v external in, so it may well be if presented with 12v it will have its own slow charge circuitry built in, but this needs confirming.
KillerWatt
« Reply #5 on: 05 November 2009, 14:03:17 »
As Zirk says, for maximum battery life you should charge at 10% of the battery A/h rating...in this case, 65mA.
Battery construction is also another factor that needs to be taken in to account where charging is concerned, use the wrong charger and the battery makes quite an impressive bang when it explodes.
« Last Edit: 05 November 2009, 14:03:55 by KillerWatt »
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
« Reply #6 on: 05 November 2009, 14:36:28 »
You might want to post the same question on the forums at http://www.yachtingmonthly.com  I find Scuttlebutt and PBO forums the most helpful :y
Page created in 0.023 seconds with 16 queries.
