Author Topic: LPG Tank Prices  (Read 1175 times)
LPG Tank Prices
« on: 16 November 2009, 15:09:12 »
Just a quick one, whats the rough cost of the 3 main LPG tanks on their own? Donut/80L/100L
Still considering donut, but keep thinking how many times do i actually use the full capacticy of the boot. I do also have access to an Omega Estate  ::)
Re: LPG Tank Prices
« Reply #1 on: 16 November 2009, 15:29:09 »
Cheapest option is the cylinder. IIRCC there's not a lot of difference (£10 rings a bell) between the 80 ans 100L tanks. I think the Vertical Torroidal works out about £150 or so more :-/ :-/
Should add... With the mileage you're intending to do I'd go for the 100L cylinder every time to reduce the number of visits to the pump :y :y
« Last Edit: 16 November 2009, 15:30:45 by Lazydocker »
Re: LPG Tank Prices
« Reply #2 on: 16 November 2009, 15:31:16 »
How much did you pay for your 80L?
Re: LPG Tank Prices
« Reply #3 on: 16 November 2009, 15:36:45 »
I've got a 90L :y :y
Was meant to be 80 but couldn't source one so I got a 90 instead. IIRCC it was about £200
Re: LPG Tank Prices
« Reply #4 on: 16 November 2009, 15:38:07 »
Easy enough to mount a 100L in there? for the extra tenner its worth going all out i guess  :)
Re: LPG Tank Prices
« Reply #5 on: 16 November 2009, 15:40:35 »
If you've got a Bose shelf it'll be easiest to remove it before fitting, then refit it at the end :y :y
Other than that I'd say probably... The 90 was a bit of a pain as the mounts fell in slightly awkward places but other than that was OK :y :y
Re: LPG Tank Prices
« Reply #6 on: 16 November 2009, 15:42:41 »
Got no Bose to worry about so hopefully should be ok  :) - cheers for the info  :y
Re: LPG Tank Prices
« Reply #7 on: 16 November 2009, 20:05:19 »
Remember you can only fill to 80% ... so a 100 litre tank gets 80 litres in .. an 80 ltr tank gets 64 litres in .. thats only 16 litres difference...
16 litres = 3.5 galls .. at around 20 mpg thats only 70 miles difference .. not a huge amount ...
It's your choice obviously .. but is the extra work worth it ??
Re: LPG Tank Prices
« Reply #8 on: 16 November 2009, 20:10:12 »
When you put it like that, nope, not far at-alll!
Re: LPG Tank Prices
« Reply #9 on: 16 November 2009, 20:56:19 »
No real extra work if you don't have the Bose amp in the way :y :y
