Author Topic: Cheapo tech 2 Software  (Read 4831 times)
iggy21uk
  • Berkhamsted - Herts
  • Omega Spotter -  tats gone tanning
« on: 15 March 2007, 21:20:31 »
Anyone with a cheapo tech 11 tried this modified version?
http://dohc.co.uk/z20let/downloads/OP-Tech2-English.zip
Link copied from .....
[size=10]Opelscanner Can owner / Cam lock kit owner [/size] [/i][/b]
Re: Cheapo tech 2 Software
« Reply #1 on: 15 March 2007, 22:08:01 »
Yes, it adds little extra.....
Markjay
  • London
« Reply #2 on: 16 March 2007, 01:29:49 »
This is the original software that that I got with my Cheapo Tech-II, and so far it's the only one that works (well, sort of works that is).
Alas, no more Omegas....
« Reply #3 on: 16 March 2007, 14:48:53 »
Right .... having plugged in my Cheapo Tech II and read the fault codes, where is the reference list as to what the numbers mean? ;D I've got codes of PO500 & PO400 on my Dog Kennel Astra TD and have no idea now how to make sense of codes.
At least I now know though what's putting on the airbag light - it's a good job I dodn't sit in the passenger seat  :-[   ;)
« Reply #4 on: 16 March 2007, 14:59:44 »
If you have access to TIS, that is the definative source.  Failing that, the topbuzz website lists most common ones...
« Reply #5 on: 16 March 2007, 15:05:07 »
Thanks. Obviously I don't have access to copyrighted info   ;) (anymore!)  but I'll have a look at Topbuzz  :y
« Reply #6 on: 16 March 2007, 15:08:55 »
Let me know if you can't find them, I'll look it up (will need year and egine)
« Reply #7 on: 16 March 2007, 15:14:06 »
So armed with :-
0400 Exhaust gas circulation valve
0500 Idle speed stepper motor/idle air regulator
As it's a diseasal with the mega expensive fuel pump it doesn't have an idle speed stepper so it must be the EGR. Oh well more money!  :'(
« Reply #8 on: 16 March 2007, 15:15:04 »
Can you send me the lists for the Omega sub functions....i.e. gearbox etc (I have a lot of the earlier KWP82 but not the later KWP2000)
« Reply #9 on: 16 March 2007, 15:16:01 »
Take it off and clean it with carb cleaner or even paint stripper
« Reply #10 on: 16 March 2007, 17:48:51 »
Errrr? What size spanner is that?  ;)  :-?
« Reply #11 on: 16 March 2007, 17:52:57 »
I've had a quick look at it. It's nothing like an Omega's EGR. It appears that it's operated using vacuum on a diaphragm via a solenoid of some description. I've just removed a whole load of BLACK oil from the vacuum lines and a trip to Tesco & back hasn't lit the EML yet I'll have another proper look tomorrow.
