Author Topic: Cannon Balls.  (Read 1932 times)
Cannon Balls.
« on: 30 October 2009, 00:12:42 »
It was necessary to keep a good supply of cannon balls near the cannon on old war ships.
But how to prevent them from rolling about the deck was the problem. The storage method devised was to stack them as a square based pyramid, with one ball on top, resting on four, resting on nine, which rested on sixteen.
Thus, a supply of 30 cannon balls could be stacked in a small area right next to the cannon.
There was only one problem -- how to prevent the bottom layer from sliding/rolling from under the others.
The solution was a metal plate with 16 round indentations, called, for reasons unknown, a Monkey. But if this plate were made of iron, the iron balls would quickly rust to it. The solution to the rusting problem was to make them of brass - hence, Brass Monkeys.
Few landlubbers realize that brass contracts much more and much faster than iron when chilled.
Consequently, when the temperature dropped too far, the brass indentations would shrink so much that the iron cannon balls would come right off the monkey.
Thus, it was quite literally, cold enough to freeze the balls off a brass monkey.
Re: Cannon Balls.
« Reply #1 on: 30 October 2009, 00:17:21 »
 ;D ;D in all, very reasonable indeed  ;D ;D :y
Re: Cannon Balls.
« Reply #2 on: 30 October 2009, 00:58:09 »
We learn something new every day.   :y :y
r1
  • nottingham
Re: Cannon Balls.
« Reply #3 on: 30 October 2009, 08:43:13 »
dont know if i should belive this
as it could be somebody talking a load of balls!!
« Last Edit: 30 October 2009, 08:45:59 by r1 »
ENFIELD_MV6
  • Enfield
  • previously from leicestershire
Re: Cannon Balls.
« Reply #4 on: 30 October 2009, 09:42:58 »
found that intresting allways wondered were the saying come from, the other one i wondered about is who thought of the saying "oh he/she is going to go ape sh1t" were the hell did somebody of think of that
Re: Cannon Balls.
« Reply #5 on: 30 October 2009, 10:13:28 »
Another one for you
- The Sailor's Word-Book, William Henry Smyth, 1867. [son of a gun is] "An epithet conveying contempt in a slight degree, and originally applied to boys born afloat, when women were permitted to accompany their husbands at sea; one admiral declared he literally was thus cradled, under the breast of a gun-carriage”.
HolyCount
Re: Cannon Balls.
« Reply #6 on: 30 October 2009, 12:07:30 »
It's amazing how many of these "wise old sayings" originate from nautical roots. Harkening back to the days when we were such a great seafairing nation.
One of my persional favourites (though not of the sea) is the "two fingered salute" or "V" sign (not as Mr Churchill performed it) ----- which was employed in the days of the Archer to show the enemy that he still had the fingers required to shoot them.  The usual practice when enemy archers were caught was to remove the "bow fingers".
Anyway ---- I will still keep the picture of a small metallic monkey, clutching his vitals on a cold morning in mind -- far more entertaining than a load of balls  ;D
rob in gib
  • Plymouth
    • Jaguar S type 3.0
Re: Cannon Balls.
« Reply #7 on: 30 October 2009, 17:05:09 »
here is another one
Manure:  In the 16th and 17th centuries, everything had to be transported by ship and it was also before commercial fertilizer's invention, so large shipments of manure were common.
It was shipped dry, because in dry form it weighed a lot less than when wet, but once water (at sea) hit it, it not only became heavier, but the process of fermentation began again, of which a by product is methane gas. As the stuff was stored below decks in bundles you can see what could (and did) happen.
Methane began to build up below decks and the first time someone came below at night with a lantern, BOOOOM!
Several ships were destroyed in this manner before it was determined just what was happening
After that, the bundles of manure were always stamped with the term 'Ship High In Transit' on them, which meant for the sailors to stow it high enough off the lower decks so that any water that came into the hold would not touch this volatile cargo and start the production of methane.
Thus evolved the term 'S.H.I.T', (Ship High In Transit) which has come down through the centuries and is in use to this very day.
You probably did not know the true history of this word.
Neither did I.
I had always thought it was a golf term.
Just chilling in the sun. I wish back in the rain like everybody else
Stevie-blunder
  • Wolverhampton
Re: Cannon Balls.
« Reply #8 on: 30 October 2009, 18:24:46 »
Correct, I never knew that either  :y
Pitchfork
  • Tadley (near Basingrad)
  • Barndances & Morris
Re: Cannon Balls.
« Reply #9 on: 30 October 2009, 18:28:46 »
so why is German is it Scheiße?? (scheisse phonetically)
English being basically a germanic language with lumps of Norman french & Latin thrown in for good measure
HolyCount
Re: Cannon Balls.
« Reply #10 on: 30 October 2009, 19:02:27 »
I gather from my family researches that the term was in common usage in England in the 11th & 12th Centuries, by the Normans.
Whether they picked it up from the Saxons (who probably nicked it from the Romans) or t'other way about I do not know.
Debs will know ..........
waspy
Re: Cannon Balls.
« Reply #11 on: 30 October 2009, 19:23:54 »
Nice one dbug :) :) :) :)
I remember my dad saying it when i was a kid. I was never allowed to say it, because he thought it was refering to a monkie's nads ;D
I shall tell the next i time i speak to him :y
« Last Edit: 30 October 2009, 19:24:36 by waspy »
Pitchfork
Re: Cannon Balls.
« Reply #12 on: 30 October 2009, 19:37:25 »
but in French it's merde, similar in spanish too, so doubtfull whether the Normans used the 'S' word
See here http://www.phrases.org.uk/meanings/cold%20enough%20to%20freeze%20the%20balls%20off%20a%20brass%20monkey.html
« Last Edit: 30 October 2009, 19:42:09 by Pitchfork »
HolyCount
Re: Cannon Balls.
« Reply #13 on: 30 October 2009, 19:47:55 »
Quite right -- probably borrowed from the Saxons
HolyCount
Re: Cannon Balls.
« Reply #14 on: 30 October 2009, 20:30:07 »
From another site:
Analysis: Clever as all that may be, whoever came up with it doesn't know shit about "shit." According to my dictionary, the word is much older than the 1800s, appearing in its earliest form about 1,000 years ago as the Old English verb scitan. That is confirmed by lexicographer Hugh Rawson in his bawdily edifying book, "Wicked Words" (New York: Crown, 1989), where it is further noted that the expletive is distantly related to words like science, schedule and shield, all of which derive from the Indo-European root skei-, meaning "to cut" or "to split." You get the idea.
For most of its history "shit" was spelled "shite" (and sometimes still is), but the modern, four-letter spelling of the word can be found in texts dating as far back as the mid-1700s. It most certainly did not originate as an acronym used by 19th-century sailors.
Apropos that false premise, Rawson observes that "shit" has long been the subject of naughty wordplay, very often based on made-up acronyms on the order of "Ship High in Transit." For example:
    In the Army, officers who did not go to West Point have been known to disparage the military academy as the South Hudson Institute of Technology.... And if an angelic six-year-old asks, "Would you like to have some Sugar Honey Iced Tea?", the safest course is to pretend that you have suddenly gone stone deaf.
Finally, all these stories are reminiscent of another specimen of folk etymology claiming that the F-word (another good, old-fashioned, all-purpose, four-letter expletive) originated as the acronym of "Fornication Under Consent of the King," or, in another variant, "For Unlawful Carnal Knowledge."
Suffice it to say, it's C.R.A.P.
