Pages: 1 [2] 3  All   Go Down
Author Topic: Pocket Tazer Stun Gun  (Read 4246 times)
Re: Pocket Tazer Stun Gun
« Reply #15 on: 25 November 2009, 09:38:47 »
CR2's have a terminal voltage of 3V, so 3 of them makes 9V.
Being Li-ion cells, they will however be able to keep the current going for much longer than a standard 9V alkaline cell.
I do doubt that the gun in that advert makes anywhere near the claimed 950 KV though
Not unless they've re-written the laws of physics! For a start the electrodes are, what? 20mm apart?
Dielectric strength of air is, at most, 3MV/m or 3Kv/mm so the electrodes will arc over at 60kV.
That advert is pure bull5h1t!
« Reply #16 on: 25 November 2009, 13:39:54 »
anyone have the courage to try those on self body ;D
http://www.stungunsupply.com/manufacturer/Barracuda-stun-guns/
"The internal circuits of most electroshock weapons are fairly simple, based on either an oscillator, resonant circuit, and step-up transformer or a diode-capacitor voltage multiplier to achieve the continuous, direct, or alternating high-voltage discharge"
imho I wouldnt trust the battery voltages only !
« Last Edit: 25 November 2009, 13:43:08 by cem_devecioglu »
Stevie-blunder
  • Wolverhampton
« Reply #17 on: 25 November 2009, 18:59:46 »
Still very funny though  ;D ;D ;D ;D ;D ;D ;D ;D ;D
« Reply #18 on: 25 November 2009, 19:11:01 »
I haven't stopped laughing since I logged on tonight! it's been a real tonic and i'm very grateful to all you guys & gals who post the jokes, keep 'em coming! ;D ;D ;D ;D ;D :y
KillerWatt
« Reply #19 on: 25 November 2009, 19:38:06 »
You can make ridiculous voltages from very small figures (I can easily make 500 KV from 1.5V), the problems arise when you want the secondary voltages (50 KV, 100 KV, etc) to be sustainable and provide enough current when under load (the human body being the "load" in this case) to achieve the desired result.
« Reply #20 on: 25 November 2009, 20:00:54 »
I could knock a circuit up that would give a 3 second pulse at that sort of voltage from such a source and a reasonable amount of mA behind it to.
I have to say......that cat would have been toast  ;D ;D :y
Made me laugh, liked that one!
KillerWatt
« Reply #21 on: 25 November 2009, 20:05:14 »
You think?  ;D ;D
« Reply #22 on: 25 November 2009, 20:13:27 »
Indeed they would.....pressed against the skin it would be interesting to know what the volts would be (any volunteers!) as it varies massively from person to person.
STMO999
« Reply #23 on: 25 November 2009, 20:17:16 »
When I was at college we use to wet the ends of the probes on the old AVOmeter and measure the resistance of our bodies. IIRC, it wasn't that great, maybe 2-3Kohms.
« Reply #24 on: 25 November 2009, 20:18:23 »
Indeed, it varies with persperation and where you do it......
KillerWatt
« Reply #25 on: 25 November 2009, 20:20:03 »
Absolutely, that is why my last test on a gun that claimed to deliver 100KV was conducted after 8 people had their skin resistance measured at the point on the body where they would have been struck.
Of all the people measured, most of the values were within 20K of each other anyway (which meant they would have felt the same if actually zapped in real life).
Off load volts = 90 KV (just about)
On load volts = 42 KV (quite dismal really)
STMO999
« Reply #26 on: 25 November 2009, 20:21:06 »
Enough to make your eyes water  ;D
KillerWatt
« Reply #27 on: 25 November 2009, 20:23:48 »
It created enough shock in one test subject that they lost control of bodily waste functions when exposed to (what had to be) at least a 10 second burst before the battery started getting flaky.
LJay
  • North Wales
  • The Acrobatics Queen!
    • 3.2 - MV6 Big Blue!
« Reply #28 on: 25 November 2009, 21:59:51 »
Killerwatt!!! :y     Might even jump start a sense of humour!!! ;) ;)
Been there, fallen over it!
KillerWatt
« Reply #29 on: 25 November 2009, 22:07:24 »
I'll buy in to that......on the proviso that you have to take a minimum 25% of the voltage that I sit back & take, for 50% of the time that I have to withstand it  ;)
Pages: 1 [2] 3  All   Go Up
