Author Topic: Scuttle drain...and I did it myself!  (Read 2091 times)
Mr Hagon
  • South West London
  • RWD and V6; the only way to travel!
« on: 20 November 2009, 22:42:22 »
Upon finding the passenger footwell carpet nice and soggy I finally got round to clearing out the scuttle drain this afternoon.
So, I have to say thanks to fellow OOFers for creating the maintenance guide that made it easy to follow.  I can confirm that a length of twin and earth is just right for the job.   :y :y
I also feel quite proud that I did some maintenance on the Mig myself for once, rather than paying someone else.  Chuffed to bits actually.  :)
The only downside is that I scratched up my arm pretty good getting it down there to remove the crud.  Just too darn lazy to remove the pollen filter.  :P
Vauxhall Omega Elite 3.2 Estate (Mar '02) in Star Silver.
waspy
Re: Scuttle drain...and I did it myself!
« Reply #1 on: 20 November 2009, 22:55:06 »
Good for you mate :y That's just the start ;)
Ian_D
  • York
« Reply #2 on: 20 November 2009, 23:29:26 »
Well done mate.  :y :y :)
[size=12]
« Reply #3 on: 20 November 2009, 23:34:06 »
You did renew it didn`t you :-/ :question
Nickbat
« Reply #4 on: 20 November 2009, 23:52:24 »
You've just reminded me I need to renew mine. When I serviced the car in August it was out of stock at Vx, so I.........forgot about it.  :-[ :P
STMO999
« Reply #5 on: 21 November 2009, 10:02:53 »
Pollen filter is probably soaked and next to useless.
MickAP
  • South Derbyshire
« Reply #6 on: 21 November 2009, 11:23:15 »
First thing I checked when I got the new Mig, all dry there.
Had the same when I'd had the TD a few months, takes a while to get it all dry.
Mick
« Last Edit: 21 November 2009, 11:24:44 by MickAP »
Omegadoha, Desert Member
  • Doha, Qatar
« Reply #7 on: 21 November 2009, 13:05:13 »
Well done. It's a nice feeling when you can carry out maintenance work yourself.  :y :y
Mr Hagon
  • South West London
« Reply #8 on: 23 November 2009, 20:34:35 »
Nope, have to be honest I haven't replaced the pollen filter.
I'll add it to the list, but what's the reasoning behind doing so.
Is it because it would have got soaked due to the water reaching it, in which case I think the water level wasn't that high (there's a water mark that makes me think this is the case) and the reason the footwell got wet was because I parked on a slope nose upwards.
Or is it just sensible due to the scuttle getting blocked and damp air being drawn through?
RichardH
  • Ireland
« Reply #9 on: 24 November 2009, 11:57:52 »
The water level may not have been as high as the filter when you were parked but it would have been sloshing around as you were driving so it is bound to have gotten a bit wet.
They are cheap and easy to replace so it's worth doing.
johndm1957
  • Bedford
« Reply #10 on: 03 December 2009, 14:31:50 »
Having just nearly drowned in my Omega, thanks again for the excellent guide.
I used a thin piece of bent bamboo with copious amounts of hot water.
Where mine is parked slightly nose up, water had run into the rear passenger footwell too....it was well over an inch deep.
After blotting with several kitchen rolls, I now have a small fan heater on low heat in the cabin to dry it out.
« Reply #11 on: 03 December 2009, 14:52:05 »
Make sure you dry the soundproofing material under the carpets as well .. acts like blotting paper and seems to hold gallons !!!!  If you leave that even slightly damp bacteria will start to grow and the stench will be horrendous .... not at all nice ... :( :( :( :( :(
Richie London
  • heathrow
« Reply #12 on: 03 December 2009, 16:48:10 »
good luck on doing the hbv then.  ;D ;D ;D
johndm1957
  • Bedford
« Reply #13 on: 03 December 2009, 16:55:22 »
Cheers for that....I expect to have the heater in there for at least a couple of days. Will make sure its throughly dried out.. :y
Martin_1962
« Reply #14 on: 03 December 2009, 20:46:40 »
Mine took lots of Vaxing, and took a month for the smell to go.
I was driving in deep floods and got swamped >:( >:( back in 2006 I think
I had disconnected the air filter pipe so I got air at bonnet level.
Page created in 0.029 seconds with 16 queries.
