Author Topic: Changed the air in your tyres, mate?  (Read 1645 times)
cruisetopoland
  • UK
« on: 04 December 2009, 16:27:31 »
I noticed in Kwik-Fit the option of having tyres filled with nitrogen instead of plain old air for £1 per wheel.
Am I missing something?
If not air, why not helium to make the unsprung weight lighter??
From this you may tell I am not a science expert, but HUH  :-?
waspy
Re: Changed the air in your tyres, mate?
« Reply #1 on: 04 December 2009, 16:31:32 »
Because your tyres would squeek :D
Selseybill
  • La Rochelle
    • 2.0 pre face, 2.2 CDX est
« Reply #2 on: 04 December 2009, 16:33:00 »
There were posting on this about 2 months ago.I think the conclusion was there was nothing to gain on a normal road car.
« Reply #3 on: 04 December 2009, 16:36:45 »
Dry nitrogen as they advertise it ( and there is no such thing as wet nitrogen !!!) is what is used to inflate aircraft tyres. It has some advantages in that ...
Pure nitrogen contains no moisture, so is hardly affected by temperature at all, it is the water vapour that is affected by temperature. Now aircraft tyres go from -44 C at altitude to around +160 C at the end of the landing (braking) run ... so are badly affected .....  your car does not, I believe, operate in such extremes.
Nitrogen molecules are the largest in the gases that constitute "air" ... it is believed that tyres with pure nitrogen hold pressure better as the molecules don't "leak" out through the permability of the tyre.
If, BIG IF, you decide to go the nitrogen route, you must then ONLY EVER check/top up with nitrogen .. or you have just undone all the so called benefits.
Even a small amount of water vapour can make a big difference ... if you think about it .. most folks will say they have to adjust their tyres less in the summer than the winter ... in the summer the air is drier .. :)
HTH
cruisetopoland
  • UK
« Reply #4 on: 04 December 2009, 16:44:00 »
HTH
Nice answer  ;)
Just searched helium in tyres on google and found that weight saving less than material needed to keep helium in...
HolyCount
« Reply #5 on: 04 December 2009, 16:50:45 »
HTH
Nice answer  ;)
Yes -- the helium molecule is a wee little beasty and can get out through most membranes !
Stevie-blunder
  • Wolverhampton
« Reply #6 on: 04 December 2009, 18:31:10 »
Pure nitrogen contains no moisture, so is hardly affected by temperature at all, it is the water vapour that is affected by temperature. Now aircrafttyres go from -44 C at altitude to around +160 C at the end of the landing (braking) run ... so are badly affected .....  your car does not, I believe, operate in such extremes.
HTH
My Mig does  ;D ;D ;D ;D ;D ;D ;D ;D ;D
« Last Edit: 04 December 2009, 18:32:46 by Stevie-blunder »
« Reply #7 on: 04 December 2009, 18:48:50 »
i am actually wondering about trying it. Currently running sports contact 3's, and have noticed they seem quite sensative to pressure. 34 or over they give a very hard ride, and 31 ish or below they go a bit hot and squidgy.
 Add in the fact 2 of the 4 seem to leak down a fraction more than i would like, meaning a week and a half of unchecked pressure can see 27 on the gauge and a ware line on the edge that looks like i've been on a track day. Not good as i've not been caining it.
 I did wonder it bigger molecules would be a good idea?
mantahatch
« Reply #8 on: 04 December 2009, 19:30:24 »
Excuse my ignorance on this but, how do they fill the tyre with just nitrogen ? I mean do they have to use a vac pump first to get all the "air" out.
Sorry for my ignorance, it is just that we use nitrogen at work and I could get it for free, but I assume there must be more to it than just releasing the air in the tyre under pressure and then refilling it.  :-/
davethediver
  • Blackburn, Lancs.
« Reply #9 on: 04 December 2009, 19:36:13 »
Not sure how they do it to be honest we used to have a compressor with a special membrane in it to remove nitrogen from air in order to give it a higher oxygen content for scuba diving. May work on the reverese principal.
But as you said do they 'Suck Out' the air thats already in to give 100% Nitrogen or is it partially blended to a high nitrogen content.
P.A. Caron de Beaumarchais
Tony H
  • liverpool
  • Black Elites are luurvley
« Reply #10 on: 05 December 2009, 00:16:45 »
I would imagine that kwik crap would just top up the tyre with nitrogen not as you would expect them to do and compleatly purge the tyre of air as should be done. Sounds like a few drops of snake oil to me :-/
cruisetopoland
  • UK
« Reply #11 on: 05 December 2009, 09:25:55 »
Snake oil and filter was £34.99  ;D
