Author Topic: tyre removal  (Read 1310 times)
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
tyre removal
« on: 03 December 2009, 14:36:59 »
got a couple of scrap sets of alloys i want to cut the tyres off. whats the best way, tried the cutting disc, seem to be breathing more smoke in than owt else.
Tia. jon :y
Re: tyre removal
« Reply #1 on: 03 December 2009, 14:40:42 »
Tia. jon :y
Pop into your local tyre place and give the boys a drink :y :y
You need to take the valve out and break the bead... Then you'll be able to do it with a couple of lever bars :y :y
The Red Baron
Re: tyre removal
« Reply #2 on: 03 December 2009, 14:42:27 »
Tia. jon :y
cheers paul. im thinking that if i weigh them in without tyres on i will get more cash.?
waspy
Re: tyre removal
« Reply #3 on: 03 December 2009, 16:18:33 »
Tia. jon :y
You'll get around £5.00 a wheel so the tyre fitter experience may not be worth while. Drill a hole in the tyre close to the bead & then jigsaw them towards the rim. Once you've popped the bead they should come off easy :)
waspy
Re: tyre removal
« Reply #4 on: 03 December 2009, 16:22:54 »
Also if they happen to be pigs to remove (sometimes they can be). Drive over the tyre with the wheel on a vehicle & that'll do the trick :y Be carefull that the wheel & tyre don't flip up & damage your vehicle ;)
It's best done slowly with someone watching.
The Red Baron
Re: tyre removal
« Reply #5 on: 03 December 2009, 16:34:47 »
thanks pete.  :y
KillerWatt
Re: tyre removal
« Reply #6 on: 04 December 2009, 00:03:19 »
Tia. jon :y
I'm not f**king surprised to be honest
Deflate the tyre (properly), break the bead, then lever it off.
The Red Baron
Re: tyre removal
« Reply #7 on: 04 December 2009, 19:08:10 »
Tia. jon :y
well thanks for your words of wisdom, do you really think im trying with them inflated, numpty.
got 4 off today, another 4 to do tommoz.
cam2502
  • dumfries,scotland
    • 08 BMW 520d & 03 Saab 95
Re: tyre removal
« Reply #8 on: 04 December 2009, 19:36:01 »
Tia. jon :y
hehe..always laugh when i hear that word ;D ;D ;D
The Red Baron
Re: tyre removal
« Reply #9 on: 04 December 2009, 19:51:21 »
numpty, yes a good one when aimed at the right person ::)
waspy
Re: tyre removal
« Reply #10 on: 04 December 2009, 20:42:47 »
How did you get them off mate?
« Last Edit: 04 December 2009, 20:43:02 by waspy »
KillerWatt
Re: tyre removal
« Reply #11 on: 05 December 2009, 08:01:04 »
You're calling me a numpty after YOU tried to use a cutting disc to remove a tyre???
The Red Baron
Re: tyre removal
« Reply #12 on: 05 December 2009, 09:00:12 »
yep,                               :PNumpty :P
The Red Baron
Re: tyre removal
« Reply #13 on: 05 December 2009, 09:02:03 »
drilled hole, sledgehammer & jigsaw for bead. :y
KillerWatt
Re: tyre removal
« Reply #14 on: 06 December 2009, 03:45:03 »
yep,                               :PNumpty :P
So just to get this straight (although I'm sure most here have worked it out)....you attacked rubber with a metal cutting disc...and then wondered why you were breathing in s**t?  :o
