MV6 Irmscher Estate Replacement Shocks
Started by Nextgen, 13 March 2007, 10:21:47
Nextgen
Hi all, great forum! i've been hanging about "elsewhere" on the web, but finally found this... with some old faces.
My question is fairly specific:
1998 MV6 Irmscher Estate: Has the factory lowered front end on it.
Are the shocks different (or is it the spring length or both)?
I'm after a good replacement MV6 shock to replace the completely knackered fronts  - the're noisy, and driving over speedbumps is an "education" in seasickness. Oh, and i've got an MOT coming up...
Nice and stiff would be good - Bilsteins?? or does any other company do after-markets.
Cheers and thanks in anticipation,
Edwin
"Don't fear the penguins!"
Admin
#1
Bilsteins are what I have got for the MV6 Saloon.
Their OE replacement are both better and cheaper than the genuine Vx ones.
I recommend Balance Motorsport. www.balancemotorsport.co.uk
Oh and good to see you again! :)
The Administrator.
Nextgen
Had a look at the rather cool Balance motorsport site - great site!
I have been told that the MV6 Shocks have OEM Part numbers:
LH side 9192291 and RH 9192292 - This right??????
(supposedly) Trade Club price £44.60 exc VAT
B4 Shocks from Balance, Don't match the OEM part numbers above
The shocks apparently replace OEM Codes:
OPEL      344227
OPEL       344236
OPEL       904 47 371
OPEL       904 47 378
OPEL       90496023
46.26 Inc VAT
Any thoughts od advice greatly apreciated,
Edwin
The thing here is that the MV6 is lowered by the shocks although In laidback66's case this is now done via the Irmscher springs...
So I would say you have two options:
1) Vx shocks....
2) Rear lowering springs and Bilstein OEM shocks....
Nextgen
#4
Aha! - Gotcha.
Let me just check:
MV6 front  and rear is lowered by the shocks, the Irmscher MV6 has GM springs and specific MV6 GM shocks *not* Irmscher springs??
- Or is it that only the rears are lowered by the shocks, and the front is dropped by the springs and can use standard shocks?
Laidback's MV6 has got Bilstein OEM replacements for non MV6 shocks, and hence would not be lowered, but he has Irmscher Lowering springs (aftermarket?) which drop it back to where it would be.
Would that explain why the rear end of my estate seems a little high in the air (I've tested the auto leveling which works and brings it back to that level) if the shocks have been replaced with "Non MV6" Items, but have the original springs?
GM shocks for the front end I think as otherwise I'd have to buy some new springs, then Lowering springs for the rear (30mm was MV6 standard?????) to go with the standard shocks????
Cheers for answers,
Edwin
QuoteAha! - Gotcha.
Let me just check:
Cheers for answers,
Edwin
There is no such thing as an Irmscher MV6.  There is an MV6 that may be loaded with any number of Irmscher goodies, which may or may not include Irmscher springs....   ....you need to check exactly what you have on...
Nextgen
Gotcha. I've been trying to clarify that for ages "elsewhere" - My misunderstanding, and apologies for time wasted!
Its a factory MV6, that has had what looks like *all* of the listed Irmscher body parts (and at one point had the exhaust) and wheels stuck on it. All the muppets advertising "Irmscher MV6"'s on ebay have had me nicely mislead -I guess I was thinking it was something like the Lotus Carlton, but Germanic in nature...;-)
Any way of easily identifying Irmscher springs from GM parts (sorry if thats a stupid question)???
Yes.....there red....and very good to...
Nextgen
Oh. All my springs are Red....  Should I be rejoicing?
QuoteOh. All my springs are Red....  Should I be rejoicing?
Sounds like Irmscher springs :y
Thats a good start....so you can go Bilstein OEM......
You will loose the self leveling rear but, thats no big deal as it will currently be canceling out the 30mm spring drop!
Nextgen
I'm guessing that you can't just get the rear back to original height by adjusting the length of the link rod to the sensor switch? I'm guessing that the self leveling shocks will be set for an intrinsicly higher ride height regardless of the pressure in them..... I'm guessing here completely, as I'm more an engine and electrics person.... suspension is a whole new world of scraped knuckles....!
theolodian
QuoteI'm guessing that you can't just get the rear back to original height by adjusting the length of the link rod to the sensor switch? I'm guessing that the self leveling shocks will be set for an intrinsicly higher ride height regardless of the pressure in them..... I'm guessing here completely, as I'm more an engine and electrics person.... suspension is a whole new world of scraped knuckles....!
According to past discussion on here there is some adjustability in the sensor.  However, I have no idea how much.
[move]Trains may have been invented here, but public transport is a foreign concept![/move]
Nextgen
One set of front B4's in the process of bring ordered: just waiting for a price for the dust covers... anyone know if i can use some new GM parts instead of bilsteins own?
Thanks for all the help!
Edwin
theolodian
QuoteOne set of front B4's in the process of bring ordered: just waiting for a price for the dust covers... anyone know if i can use some new GM parts instead of bilsteins own?
Edwin
Please keep us posted.  I am about to order B4's as well, need them by the end of next week.  I haven't looked at my old dust covers yet.  Are you replacing anything else?
