Author Topic: traction control?  (Read 1988 times)
yatesDELTA
traction control?
« on: 17 December 2009, 23:09:27 »
So i was driving to work, its covered in snow. decided i would need traction control on so pressed the button and the light comes up on the dash. Anyways it was not at all helpfull and i got stuck several times, didnt get to the motorway and decided to come back. My son seems to think the light on the dash is to say its not on? is this true? so effectively i turned of the device to control a RWD v6 car the only time it might have been helpfull?
Re: traction control?
« Reply #1 on: 17 December 2009, 23:12:33 »
button pressed light ON = Traction control DISABLED  (OFF)
The default setting is light OUT Traction control ENABLED (ON)
so .. just when you need it most .. you turned it off ....  :)
Please read the manual ???   :)  pages 152 & 153  :)
http://homepage.ntlworld.com/andrew.reynolds983/Manuals/Omega2002Manual.pdf
« Last Edit: 17 December 2009, 23:13:39 by entwood »
« Reply #2 on: 17 December 2009, 23:12:36 »
Your son is correct 8-)
Beat me by seconds :P
« Last Edit: 17 December 2009, 23:13:25 by RobG »
zirax
« Reply #3 on: 17 December 2009, 23:16:22 »
Your son is right. It's on all the time and when working it will blink. You will feel it cutting the power of the engine. When the light is on after pressing the button, it means its off (or there is a fault)
edit:- damn my slow typing
« Last Edit: 17 December 2009, 23:16:56 by zirax »
Dr Richard Stephens:- "I would advise people, if they hurt themselves, to swear."
yatesDELTA
« Reply #4 on: 17 December 2009, 23:23:55 »
If i had known this mighta gone into an empty carpark and had some fun  ;)
« Reply #5 on: 17 December 2009, 23:29:59 »
which is just what I was doing earlier.At work,no-one else here,circular road about 400 metres long with car parks off to each side.Having childish fun steering it on the throttle and handbrake turns. [smiley=evil.gif] [smiley=evil.gif]
« Reply #6 on: 18 December 2009, 00:30:26 »
I had to run the sister in law to the shop earlier.... At walking pace turned 160 degrees or so in the entrance of a side road ::) ::)
Mig was well behaved really, same as last year, but I have just filled both fuel tanks which gives a good 100kg or so over the back axle :y :y :y
Expecting a call any minute from the Brother in Law to say he's got his Volvo stuck ;D ;D ;D
« Reply #7 on: 18 December 2009, 09:43:54 »
traction control is ALWAYS on by default
« Reply #8 on: 18 December 2009, 09:50:42 »
Get some weight in your boot and set tyre pressures to minimum....
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
« Reply #9 on: 18 December 2009, 09:53:11 »
....dont and have some fun  ;D
« Reply #10 on: 18 December 2009, 09:57:14 »
had a "nearly" on the way in. Very badly gritted A road leading to a traffic lit round about with a main carriage way through the centre. 25 on approach throttle off well early, lights changed to red braked, abs banging away, lift, brake, lift, brake, cars start to pass in front, lift brake lift brake. No chance, had to turn left and go round the round about and wait at each set of lights or go through the centre through road and hit a car or 2. Still over shot the line by 15ft. Whoops.
Brick Tamland
  • Dublin
  • Good one!
    • '98 2.5 Manual
« Reply #11 on: 18 December 2009, 10:06:20 »
[media]http://www.youtube.com/watch?v=rbRXpdwZiJU[/media]
Saving for one! All donations welcome, ask for details.
Richie London
  • heathrow
« Reply #12 on: 18 December 2009, 10:58:54 »
oh my god!!! when i go racing down the country lanes i press the button. i thought you had to enable it yourself  :-[ :-[ :-[ :-[
« Reply #13 on: 18 December 2009, 11:02:17 »
The light is there to indicate a fault, or that its switched off  :)
It will flicker when its being used, take the car out now, and boot it in some snow you will see the ABS light flicker as it tries to get traction
Richie London
  • heathrow
« Reply #14 on: 18 December 2009, 11:05:24 »
got to walk down and get some petrol first, i thought i had enough so didnt bother going in the garage when i passed it, went to start yesterday and conked out as i put it in reverse  ::) ::) ;D ;D
