Author Topic: Who was it fixed the xbox rrod?  (Read 2119 times)
KillerWatt
Re: Who was it fixed the xbox rrod?
« Reply #15 on: 23 December 2009, 21:00:13 »
So you agreeing that reflow equip needed then ;)
A revised airflow is certainly something MS need to address, but if the PCB wasn't under such strain to start with then I have no doubt the manufacturer soldered joints would hold a lot longer than what they do now.
« Reply #16 on: 23 December 2009, 21:00:15 »
depends what error it actually is  ;)
« Reply #17 on: 23 December 2009, 21:01:07 »
ultimately can only be done properly with proper reflow equipment, but the online bodges may provide a temporary fix
The actual problem is the PCB bends ever so slightly when the box goes back together..and as the GPU is an SMD (Surface Mount Device)...the rest is obvious for those with even a passing interest in the basics of physics.
As you say, online "bodges" hold the problem at bay for a while (quite a while actually)...but the only real fix is to build the bastard properly to start with.
Simply re-flowing wont do it......you need to remove, re-ball (or obtain new parts), clean PCB, dry out re-balled devices (to avoid popcorning), refit....hence why it does not get down.
Costs us around 100 quid a device to get a 1500 pin 0.8mm pitch BGA device re-worked
« Reply #18 on: 23 December 2009, 21:01:43 »
Yes, teh design is shite. But my point is your £5 clamping kit won't be a proper fix to a rrod xbox!!!
« Reply #19 on: 23 December 2009, 21:03:46 »
And the re-flow profile must be fine or the joints would be failed at the end of the line.
Sadly, surface mount BGA profiles are something I know much to much about.
« Reply #20 on: 23 December 2009, 21:05:13 »
Obviously, I bow to your expertise in your specialist subject - my point being a £5 kit ain't gonna fix jack....
KillerWatt
« Reply #21 on: 23 December 2009, 21:07:56 »
Our 360 was an original Nov 05 release (pre-order).
It failed with the RROD in Jan 09 (2 months after the "extended" warranty"), it's been running sweet since the modded X clamp was fitted so I've had my moneys worth as far as I'm concerned.
Besides, they are so cheap to buy now (and even more easily "spoken to" than before), so buying a new one at some point (if I actually have to) to keep the kids happy won't phase me much.
« Last Edit: 23 December 2009, 21:08:28 by KillerWatt »
« Reply #22 on: 23 December 2009, 21:09:45 »
Happily,I have no idea what any of you are talking about. ;D...........got 3 of the contraptions here-one under the bed suffering from rrod,one a few months old working fine so far and another complete with guitar hero world tour (includes a guitar/drum kit and various other things) which hasnt even been taken out of the box yet and hopefully never will.
« Last Edit: 23 December 2009, 21:10:13 by albitz »
« Reply #23 on: 23 December 2009, 21:11:28 »
As DTM often says, we could be going down the mis-diagnosis route here. RROD needs to be clarified, it does not automatically mean over heating issues, is it all sections of the ring or just 1 or 2?
Also what code is being thrown up.....
I had 25% of RROD, due to the box crashing loading a COD4 server. I yanked the power cable out, since caused an E73 error which is network related. Couple of times a month on boot, it fails to boot and gives 25% RROD. I force it into an over heat, which sets it into 'safe' mode, and it boots fine and runs fine for a few weeks.
« Last Edit: 23 December 2009, 21:13:47 by tunnie »
