Author Topic: 34 years of faithful service  (Read 6762 times)
jereboam
  • Suffolk
    • 1999 Omega Elite 3.0
« on: 27 December 2009, 17:55:52 »
My amplifier stopped working.  Just like that - no bang, no smoke, no flames.  It just stopped.  Checked the fuse - it had blown.  Zoomed into town and just caught Maplins as they were closing.  Replaced fuse.  Blew immediately - no surprise there.
Anyone got any suggestions?  I'm reasonably competent with a soldering iron, and I've got a multimeter.  What I haven't got is enough money to buy a new one.   :'( :'( :'(
STMO999
Re: 34 years of faithful service
« Reply #1 on: 27 December 2009, 18:30:24 »
Sorry I cant help J, but I'm sure someone will take the piss help you soon.
« Reply #2 on: 27 December 2009, 18:49:50 »
Come on, give us a clue....you have an old amp thats stopped working and its blowing fuses....
Make
Model
Type
Which fuse
STMO999
« Reply #3 on: 27 December 2009, 18:57:39 »
Probably the pins on a valve shorted out. ;D
STMO999
« Reply #4 on: 27 December 2009, 19:02:29 »
He must be having his nap.
Omegadoha, Desert Member
  • Doha, Qatar
« Reply #5 on: 27 December 2009, 19:03:13 »
Probably has vintage value that amp.
« Reply #6 on: 27 December 2009, 19:04:59 »
Chances are that if its the mains fuse it could be a possible dead rectifier diode/bridge
STMO999
« Reply #7 on: 27 December 2009, 19:08:03 »
On something that age, it could be as simple as a worn power flex shorting out, but I'm no good at long distance diagnostics.
« Reply #8 on: 27 December 2009, 19:15:18 »
Just thinking the same thing.
« Reply #9 on: 27 December 2009, 19:19:37 »
Lol, I am hoping said person is not quite so stupid to of not checked,
I have to say that I dont agree with the 2 of you, if it was an iron, vaccum or something that was often moved, wound etc then yes.
Plus mid seventies the plastics were reasonably ok.
STMO999
« Reply #10 on: 27 December 2009, 19:22:28 »
Only said 'could be'. It 'could be' a good few things.
I doubt we'll ever know.
jereboam
  • Suffolk
« Reply #11 on: 27 December 2009, 19:32:56 »
No - I was off doing the IQ test.
Did that OK, but can't remember my username/password for the AVforums. :( :(
Debs.
« Reply #12 on: 27 December 2009, 19:43:52 »
.......Heater, Cathode, Grid, Anode......or insufficient vacuum! :P
STMO999
« Reply #13 on: 27 December 2009, 19:47:42 »
You forgot the top cap.
jereboam
  • Suffolk
« Reply #14 on: 27 December 2009, 19:49:36 »
OK
It's a Sansui AU4400, and it was the 1.5A case-mounted fuse which blew.  As far as I remember, its rated at about 30w RMS per channel.  Shouldn think it's got any valves in it, but from the 1975 vintage, I'd guess it's mostly discrete components.
It's unlikely to be the external connections, as nothing else in the stack has been affected.
Beautiful!
