Author Topic: It was going so well......  (Read 1088 times)
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
« on: 31 December 2009, 13:30:56 »
On my way to the MOT center I decided the cats needed a blowout to dust off the cobwebs so decided to go the long way around.
As I turned to go past Tescos a lot of steam was coming out the back. I pulled over and the steam was so thick it was didfficult to see through.
I was gutted.
Worried I hadn't done the oil cooler job properly I filled her back up with coolant right to the brim only to find the level dropped only 2-3cm.  Not a good sign, that is approximately the level of the oil cooler.
limped her home watching the needle the whole way and got the plenum off and down to the V in record time.  the pipe from the coolant bridge to the HBV had sprung a considerable leak.  A quick trip to the local stealers confirmed they are useless so I went home and bodge repaired the original.  Thankfully the split was right by the end so I only had to take off 2cm off.
Got her back together and started her up.  She runs smoothly but I am worried there may be HG damage.
STMO999
Re: It was going so well......
« Reply #1 on: 31 December 2009, 13:41:18 »
Tough luck Matt. Did you get as far as the MOT centre or is that it till new year now?
PS. Buy an astra :y
Omegadoha, Desert Member
  • Doha, Qatar
« Reply #2 on: 31 December 2009, 13:41:48 »
I was gutted.
Sorry to hear about that, lets hope you did no damage to the HG. You made it sound like that you went especially to the stealers just to confirm that they are useless. PMSL ;D ;D
You stated that it all went wrong as you went pass Tescos. Wonder if you could claim against Tesco.  ;D
Gaffers
« Reply #3 on: 31 December 2009, 13:48:02 »
PS. Buy an astra :y
Saturday now :(
Gaffers
« Reply #4 on: 31 December 2009, 13:48:45 »
I was gutted.
Nice thought but unless we bring in Sharia law that aint gonna swing...
p j morgan
  • nottingham
« Reply #5 on: 31 December 2009, 13:52:18 »
lets hope you aint done any damage to the hg ?if she is running ok  sounds like you have got away with it ? good luck with her ! a happy new year should be in order 8-) :y
STMO999
« Reply #6 on: 31 December 2009, 13:56:21 »
You must be really unlucky mate. I've hardly ever heard of an omega going wrong like that. ;D
« Reply #7 on: 31 December 2009, 14:32:00 »
Must be almost 24 hours since I heard of one . :y ::) ;D
« Reply #8 on: 31 December 2009, 16:10:15 »
Never mind G, at least you salvaged something from what could have been a disaster.
Saturday, being another day, brings the prospect of renewed success. :y :y
Gaffers
« Reply #9 on: 31 December 2009, 16:22:43 »
The bonus is that it would appear the HG is in tact for now, the problem is crank sensor, phew :y
sparten
  • ffoss-y-ffin,near aberaeron
  • usually,fixing his miggy
« Reply #10 on: 31 December 2009, 16:36:12 »
i too changed my oil cooler ,new oil filter,oil every thing nice and tight,yer right,started her up and a sh#t load of oil sprayed out of oil filter housing,retightend up now the crank senser is leaking so know a new senser will have to be order'd  :(
