Author Topic: Laptop Query?  (Read 5109 times)
Cliffo B
  • Leeds West Yorkshire
    • 03 3.2 Elite Estate
Laptop Query?
« on: 26 December 2009, 23:49:41 »
My computer crashed a few weeks ago,and the one I  replaced it with wont shut down the cooling fan. Is this correct? It is a HP laptop 6910p, used but refurbished, it may be a daft question but I know very little about computers so any help would be appreciated.
Broomies Mate
  • Bristol, UK
    • Stuff!
Re: Laptop Query?
« Reply #1 on: 26 December 2009, 23:56:12 »
What is your CPU usage?  Press Ctrl + Alt + Delete simultaneously and then click the 'Performance' Tab.  Monitor it for 10-15 seconds and then guesstimate an average.
Re: Laptop Query?
« Reply #2 on: 26 December 2009, 23:59:27 »
Whilst running, or after you turn off the laptop?
Cliffo B
Re: Laptop Query?
« Reply #3 on: 27 December 2009, 00:11:32 »
thanks Scruntie, after I turn off it will run forever untill battery goes down.
Re: Laptop Query?
« Reply #4 on: 27 December 2009, 00:16:34 »
Feel rond the sides for the air vents and see if they are clogged with dust, it may make a difference, but does sound like there is a fault.
I would also be tempted to log into the bios setup screen on boot up and check to see how the cooling fans are set in the system settings.
Has the fan been like this from you buying it, if so I might be tempted to think it has been done like this on purpose to sort an an orriginal issue.
Broomies Mate
  • Bristol, UK
    • Stuff!
Re: Laptop Query?
« Reply #5 on: 27 December 2009, 00:22:01 »
I have hard-wired cooling fans in several of my past laptops after suffering overheating problems.
Ken T
  • Stockport
Re: Laptop Query?
« Reply #6 on: 27 December 2009, 00:33:07 »
Oh Dear. There is a problem with a lot of the DV6000/ 9000 series of HP laptops, in that they screwed up the design and used nvidia chips, designed for a desktop in a laptop. Trouble is in a desktop, the chip gets up to working temp and stays there, cause it is continually cooled, however in a laptop they only cool when the processor needs it, as its quieter and saves power. So the Nvidia chip get hot then cold then hot then .... which wears it out, so it dies a lot faster. The way to prolong its life was an "upgrade" from hp that basically kept the fans on all the time. If your fan  is running all the time, it sounds like it has the upgrade, although it shouldn't run when shut down. If its doing that, the fan supply is somehow bypassing the shutdown voltage control which it shouldn't cause most of the voltage regulators are shut down. I wonder if some clever sod hasn't wired the fan onto the battery supply ?.
Once shut down, to stop the fan, just remove the battery. To prolong its life, avoid switching it off and on, eg if you are going to use it on one day, leave it switched  and avoid thermal cycles, eg heat up, cool down etc.
If you get bored, Google for Nvidia GPU problem.
Ken
Cliffo B
Re: Laptop Query?
« Reply #7 on: 27 December 2009, 00:47:21 »
Hello, recieved this laptop on xmas eve day so can,t take it up with supplier until next working day.your comment could be correct cos when I first powered it up it worked Ok for a few minutes then became intermittant I finally discovered the power supply lead was damaged  at grommet where it connects into the computer port.I sorted this by replaceing the power supply complete as my previous computer was a Hp and it was the same.I didn't know if some laptops fans ran all the time this fan runs at full lick when windows shuts down and hardly at all when windows is running Thanks Scruntie I now know it is a fault and can take it up with the supplier
Cliffo B
Re: Laptop Query?
« Reply #8 on: 27 December 2009, 01:09:44 »
oh heck, can it be a faulty laptop? Its under HP warranty for a yr. I'll just not suffer faulty things. By what you now say I might be better getting it returned and  a full refund. Ken can you give me your opinion, thanks
Ken T
  • Stockport
Re: Laptop Query?
« Reply #9 on: 27 December 2009, 02:21:35 »
Hi Cliffo,
There is a lot of politics here, I'm an engineer, I make things work, not deal with this crap. You are protected under trading standard legislation to a certain extent, I'll reply with details tomorrow.
Question, did you buy it new or 2nd hand, who did you buy it from, do you still have the receipt ?.
On the engineering front, I repaired one of these a while ago, and posted pics. It still works !. There is a way of repairing them, but........
More tomorrow.
Ken
Re: Laptop Query?
« Reply #10 on: 27 December 2009, 10:43:25 »
I personally would try andreturn it and maybe take an upgrade to a different model if given the chance.  You mentiobed it was a refurb, so in my mind it allways begs the question why was it a refurb, half the time they just say damaged box or parts missing, but in this case maybe not.
Ken T
  • Stockport
Re: Laptop Query?
« Reply #11 on: 27 December 2009, 12:13:03 »
If the psu lead is faulty, that needs to be replaced. As regards the laptop you have to work out if what you paid is worth maybe only 1 year's use. The laptop may last longer, but you don't know. My son had his DV9000 fixed by them; it lasted a whole 4 months and died again. Its not just hp, Dell also had the problem although not as much, perhaps their cooling is better. Even Apple had (and are still having) problems as they used Nvidia chips in some products.
HP offered a free extended warranty   http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&lc=en&cc=us  world wide, which gave a garanteed 2 year life, although in my view that's not a lot if you paid £700 for a dv9000
My view is if you paid good money, say over £225, tell them its fundamentally flawed and to take it back. If its about the price of a 2nd hand one, say £150, then that's not bad; you may get a couple of years out of it, and they are worth about £60 scrap on fleabay.
Ken
Ken T
  • Stockport
Re: Laptop Query?
« Reply #12 on: 27 December 2009, 12:15:25 »
Oh yes, if choosing a replacement, its the Nvidia graphics chipset to avoid. The intel DV's also failed although not as much as the AMD ones, and weren't covered by warranty.
Ken
Re: Laptop Query?
« Reply #13 on: 27 December 2009, 12:17:36 »
You replaced a PC just cause it crashed  :o :o
When is this cooling fan staying on? During normal use or when you have shut it down?
My first thoughts are your putting it in standby, and not shutting it down fully. - Hence cooling fan staying on.
What are you actually doing when powering off? Just closing the lid?
« Last Edit: 27 December 2009, 12:18:59 by tunnie »
Re: Laptop Query?
« Reply #14 on: 27 December 2009, 12:29:02 »
Keep up Tunnie, reply 3
Too much  [smiley=beer.gif] [smiley=beer.gif] [smiley=beer.gif] [smiley=beer.gif] at Christmas.   :-X  ;D ;D
« Last Edit: 27 December 2009, 12:29:39 by skruntie »
