Author Topic: aa battery trouble  (Read 1715 times)
r1
  • nottingham
aa battery trouble
« on: 22 January 2010, 21:43:37 »
bought 4 new aa batterys used 3 and stuffed one in my pocket,sitting down and all of a sudden my legs burning.the aa battery is red hot had a few nuts and bolts and a bit of change in my pocket.
can aa batterys short out?anybody else had this happen?
STMO999
Re: aa battery trouble
« Reply #1 on: 22 January 2010, 21:44:52 »
It shorted out your nuts??? :o
KillerWatt
« Reply #2 on: 22 January 2010, 21:47:01 »
Any battery can short out, and as a single AA battery can easily supply in excess of 1A in a short circuit surge - I'm not surprised things got warm  ;D
  • Auckland
    • Mazda MPV
« Reply #3 on: 22 January 2010, 21:48:14 »
Some Duracells have a 'test strip' on the side.
If you press it I think it uses battery power to heat up a temperature sensitive strip down the side.
Could your small change have pressed the test strip?
STMO999
« Reply #4 on: 22 January 2010, 21:49:20 »
Of course, you sh!ttin yourself probably didn't help. ;D
Did you suddenly remember all those silly stories about spontaneous combustion? ;D
KillerWatt
« Reply #5 on: 22 January 2010, 21:50:33 »
The test strip requires a small degree of concerted effort to activate, and certainly doesn't produce noticeable heat.
r1
  • nottingham
« Reply #6 on: 22 January 2010, 21:54:36 »
no wasnt a duracell
mrs thought it was well funney me hopping round the room while shes watching popstar she thought i was taking the mick
STMO999
« Reply #7 on: 22 January 2010, 21:55:13 »
no wasnt a duracell
No..... ;D
alunonhisown
« Reply #8 on: 22 January 2010, 21:55:28 »
A little related,
I use a radio scanner (AOR8000) and my mains lead is bust, and AOR in Derby are out of stock for a few weeks.
So I bought myself some rechargeables in Tesco along with 4 AA batteries, now then, this is the tricky bit, 4 X AA Duracell fit nicely in the battery compartment and re-attach battery cover, yet when I put in the re-chargeables, they keep popping out and I cannot for the life of me get the cover back on, so I am assuming that the Tesco batteries must be FATTER, they are 2900mAh, so is this why they do not fit?
« Last Edit: 22 January 2010, 21:56:06 by alunonhisown »
« Reply #9 on: 22 January 2010, 21:58:16 »
A little related,
Easy.......You've picked up C cells ::) :P ;D ;D ;D
Seriously though... I've never noticed any problems with rechargeables :y :y
alunonhisown
« Reply #10 on: 22 January 2010, 22:00:32 »
C CELLS?
And they work perfect, but cannot get the cover on.
« Reply #11 on: 22 January 2010, 22:02:10 »
A little related,
I have noticed that some cheaper rechargeables have a thick plastic sleeve around them for some reason ... this makes them hard to fit in certain devices ....
« Reply #12 on: 22 January 2010, 22:03:22 »
C CELLS?
The next size up from AA... Fat ones which wouldn't fit :D :D :D
Sorry... Was my odd sense of humour :-[ :-[
« Last Edit: 22 January 2010, 22:03:40 by Lazydocker »
sexydaz
« Reply #13 on: 22 January 2010, 22:41:10 »
and it got that warm the end of his bolt had a red end ::)
