Author Topic: MOT failure rates are revealed for the first time  (Read 3053 times)
BigAl
  • Bromley, Kent
    • '07 Forester
« on: 13 January 2010, 11:31:40 »
http://news.bbc.co.uk/1/hi/business/8456116.stm has a link to an excel spreadsheet of MOT pass rates and failures for 2007 and is quite interesting, if you like that sort of info
« Last Edit: 13 January 2010, 11:32:02 by BigAl »
Re: MOT failure rates are revealed for the first time
« Reply #1 on: 13 January 2010, 11:35:27 »
Omega Info:
Year of      Test      Test      Failure      Body and            View of      Fuel and
First Use      Passes      Failures      Rate      Structure      Brakes      the Road      Exhaust
1971*      6      8      57.1%            5      4      2
1990      1      2      66.7%            2      1
1994      1,792      1,841      50.7%      215      2,072      577      801
1995      2,908      3,014      50.9%      197      3,486      867      1,373
1996      3,625      3,501      49.1%      141      3,827      960      1,462
1997      4,203      3,612      46.2%      132      3,069      952      1,488
1998      6,428      5,242      44.9%      132      4,315      1,260      2,034
1999      7,101      4,932      41.0%      89      3,602      1,089      1,765
2000      6,977      3,640      34.3%      35      2,131      733      1,212
2001      6,210      2,809      31.1%      26      1,161      482      985
2002      6,128      2,168      26.1%      18      865      324      650
2003      3,926      1,219      23.7%      7      364      134      240
2004      177      35      16.5%            8      5      5
Total      49,482      32,023      39.3%      992      24,907      7,388      12,017
« Reply #2 on: 13 January 2010, 11:42:12 »
Plus I would imaginge with the cost of the MOT and the retest, people are now aiming to get it rught 1st time.
But, is a failure classed as a fail on the test, or failure after failing the retest?
« Reply #3 on: 13 January 2010, 11:59:44 »
Although there are no targets, I have been told there is a traget of around 30% failure
« Reply #4 on: 13 January 2010, 12:51:58 »
The Ford Transit Connect had the highest failure rate
Surprise, surprise! Vehicles that get not the slightest bit of attention from either driver or owner fail the MOT.
Saw a 55 plate one in our village, front totally stoved in after an accident on the snow. Both front tyres down to canvas. Not ideal for driving in winter, really. ::)
« Reply #5 on: 13 January 2010, 14:30:23 »
'My' MOT tester said that VOSA had questioned his generally low fail rate.  :-?
« Reply #6 on: 13 January 2010, 14:43:12 »
What I find amazing is that the majority of "fails" are for just 2 areas .... "brakes" then "lights & signals" with the next lot being "suspension", Tyres", "Fuel & exhaust"
Now I accept that the majority of folks out there may not be able to physically check Brakes, Suspension, Fuel & Exhaust but EVERYONE can check lights, signals and tyres .. in fact not CAN .. the word is SHOULD !!
Radiomarko
  • Sunny Devon
« Reply #7 on: 13 January 2010, 15:05:00 »
Very revealing, thanks OP!
I hate seagulls.
« Reply #8 on: 13 January 2010, 15:29:03 »
Agreed. But the sheer number of cars on the road with lights out (even headlights FFS!) makes me believe that the average motorist is neither capable nor interested and just leaves it to be picked up at MOT time.
In addition, regarding brakes, I have been pulled up  where the brakes have been perfectly OK performance-wise but the tester has not been happy with the remaining friction material at 3 or 4 mm or more. Now, for me at that level I'm making a mental note to get some more pads and change them when I get a spare evening but I'm, guessing MOT testers now work on the assumption that if it is going to require attention during the next year they fail it. :(
« Reply #9 on: 13 January 2010, 16:14:12 »
lights failing is of no suprise, i reckon 1 in 10 cars i see have some sort of light issue, either bulbs or headlight alignment related. Easy to check as you say but people just dont bother...
Hannah Judes Dad
    • the misses round the bend
« Reply #10 on: 13 January 2010, 16:36:53 »
[/highlight]
I can vouch for that swmbo hasn't got a clue and I have done hers three times in the last few months(bulbs that is)
Martin_1962
« Reply #11 on: 13 January 2010, 17:15:33 »
MOT testers can be done for not failing, so my usual tester fails borderline cars then passes them to get his failure up.
Nothing wrong with them but it save the ministry annoying him.
« Reply #12 on: 13 January 2010, 17:58:37 »
And I think everyone knows what I think of this policy. Air Freshener, I rather ask you  >:(
BigAl
  • Bromley, Kent
    • '07 Forester
« Reply #13 on: 13 January 2010, 18:15:30 »
It was in the back of my mind, how long before air fresheners would be mentioned ;D
Hannah Judes Dad
« Reply #14 on: 13 January 2010, 18:29:40 »
It may well have been in the back of your mind but from what I can gather not in the back of TB's mind,more like all over his car
