Author Topic: Aquarium fish problem (advice needed)  (Read 2592 times)
Plomien
  • Swansea
    • Landrover Freelander TD4
Re: Aquarium fish problem (advice needed)
« Reply #15 on: 22 January 2010, 22:43:23 »
unlucky alf
  • worksop, notts
« Reply #16 on: 22 January 2010, 22:48:46 »
the plecs ive got are commonly known as butterfly plecs that only grow to about an inch,& not those tropical ones which get huge even though i had one in with my cold water fish with no problem until he got bigger & moodier ;), anyway even if you isolate your blackmoor it might be an idea to put some aquatic salt in your tank to kill off any spores.
mars
  • Cannock, Staffordshire
    • Vivaro Sportive BMW 330d
« Reply #17 on: 22 January 2010, 22:49:17 »
Our pleck fish are tiny; about 1cm if that. They are lightning fast (when they move, not very often though!) but do a good job of keeping the tank clean; a huge difference to what it was like before we had them.
There is no such thing as bad beer, some beers are better than others.
sexydaz
« Reply #18 on: 22 January 2010, 22:54:39 »
http://www.fishkeeping.co.uk/index.php
ive been on here a few times for advice
« Reply #19 on: 22 January 2010, 22:58:17 »
The two pleccys we had (was living with a G/F who had 2 kids) were named George and Bungle by the kids.  As you say they do a brilliant job of tank cleaning and a bloody quick.
unlucky alf
  • worksop, notts
« Reply #20 on: 22 January 2010, 22:59:01 »
swimbladder  problems you to tend get with fantails due to the way their internals are squashed up, ive found that blackmoors tend to stress pretty easily also, if you want to get some fun fish try getting a pair of weather loaches, these are the only fish ive seen f4rt believe it or not. ;D ;D
jerry
« Reply #21 on: 22 January 2010, 23:04:37 »
You can get plecs  that will be fine in c/w, Hong Kong plecs for example. The problem with some species is that they just keep growing.As for your  swimbladder case, I'm afraid that in my experience that its very unlikely that the fish will recover from this. As Mr E and others have said, if you can then isolate this fish to treat and then do water changes on the main tank but make sure you monitor the ph as you do so and use salts etc to correct where needed. Most specialist fish retailers should be happy to give you some advice. Good luck :y
Turk
  • Llanelli, Wales
    • 2.5td, H-D XL1200
« Reply #22 on: 22 January 2010, 23:13:56 »
I agree with Entwood.
When you say placs, do you mean, Plecostomus
Are these the ones, http://en.wikipedia.org/wiki/Plecostomus
But I also ask a question.  Are the plecs not tropical fish, how long have they been in the tank.
They are coldwater; we had one last 18 months in the same tank, the current ones have been in there a few weeks :y
We have two in work, one is just over a year old and is in with 4 catfish and about 30 Malawi Cichlids. The other is at least five years old and lives with two Oscars. Now that's one seriously big Pleccie !
« Reply #23 on: 22 January 2010, 23:17:40 »
I know nowt about coldwater, but if it was a tropical tank I would oick him out and treat for swimbladder in a seperate tank.
I have found the chemicals for SB to be harmful to other fish, and the success rate is very low anyway.... so the ill fish dies and gets eaten by the others, so spreading the infection.
The fungal growth will be present in the tank now in spore form .. so you'll have to keep a very close eye on the other fish in case they get it as well.
If the fungal treatment you are using mentions a water change after some time .. make sure you do it and do it on time ... some fungal treatments are long term poisons to fish.
Thanks for your advice; was thinking of separating him so will try that now. We bought him just under a month ago from pets at home and he seemed very healthy until yesterday :o
I have never bought a fish from there that has lived more than a very few weeks, I not longer use places like that or Garden centres etc.........
sexydaz
« Reply #24 on: 22 January 2010, 23:24:18 »
;Dif it wasnt you,d just have two oscars ;D
Turk
  • Llanelli, Wales
    • 2.5td, H-D XL1200
« Reply #25 on: 22 January 2010, 23:33:01 »
;D You're not wrong, and the Oscars are pretty hefty too.
« Reply #26 on: 23 January 2010, 11:30:16 »
 Right.
Fishkeeping.....fish keep themselves, YOU keep the water, and feed.
So, for disease to set in, needs a trigger, such as stress from bullying, bad water quality etc.
If there is nothing obvious going on, 1st thing to do is quite a big water change, dilute whatever crap they are swimming in.
then treat and visible disease, such as fungus, swimbladder issues, ulcers etc, as stated salt is good for swimbladder issues, (iirc 1 teaspoon per gallon, but been some time since I worked in the trade.)
IF you can seperate the poorly fish, this can be beneficial if it remains in a good enviroment.  however treat both normal tank and treatment one, kill off whatever is the problem.
As for plecs, there are many species, and a fair few of them are fine in a wide temperature setting, even ok in ponds during the summer.
adding new fish, which dont last is rarely anyones fault, its stressful moving the fish, and they go from one water quality to another, different temp, ph, hardness etc etc etc, and the shock of this move often upsets fish, hence the 24 /48 hour guarantee's you get, also if you filter system isnt up to scratch, adding new fish increases waste in the tank which the filter takes time to adjust to, which on top of the stress, can easily see off the new fish. (the existing stock have had no stress so cope better)
Hope this helps.
mars
« Reply #27 on: 25 January 2010, 20:43:06 »
Thanks to everyone for their advice. Unfortuneatly the large Black Moor and the two plecs died. My wife rang Pets at Home this morning and I went in there after work with the receipt for the fish which totalled £30. They have now refunded us the money, the 3 fish we have just lost were the 3 bought on December 27th. All our others which have been in the tank from 6 months to 2 years still seem fine but time will tell.
