Author Topic: cat replacement  (Read 1128 times)
bluehawk
cat replacement
« on: 27 January 2010, 11:37:41 »
had a new exhaust 12 dec fortunaly its under warrenty as the weld has gone and need the front down pipe including cats replacing  >:( no quibbles from garage  ;D repaling straight away
Re: cat replacement
« Reply #1 on: 27 January 2010, 11:49:17 »
where exactly has the weld gone, are you refering to the exhaust flexi weld which is post cat, and before it bolts to the main exhaust?
bluehawk
Re: cat replacement
« Reply #2 on: 27 January 2010, 12:18:18 »
yes the weld s gone just after the flexi before it meets th emiddle boxs
Re: cat replacement
« Reply #3 on: 27 January 2010, 12:21:52 »
In that case, you don't need a replacement Cat (although Vx will say you do)
You can buy a replacement flexi for about £15, take the down pipe off, and cut the old flexi out, and weld the new one in.
MarkDTM expertly did mine few months ago, might be worth dropping him a PM.
I need to do the same on father tunnies 2.2, going to have a bash at this one myself, and borrow welder from TB.
I can't remember the diameter you need though for the flexi  :(
EDIT - I'll take the camera and do a how2 when i do father tunnies  :y
« Last Edit: 27 January 2010, 12:26:22 by tunnie »
cruisetopoland
  • UK
Re: cat replacement
« Reply #4 on: 27 January 2010, 12:27:23 »
welung666 replaced flexi pipe on my cat, good as new  :y
Re: cat replacement
« Reply #5 on: 27 January 2010, 12:34:23 »
But why bother DIY when it's under warranty ::) ::)
Re: cat replacement
« Reply #6 on: 27 January 2010, 12:36:14 »
Flexi is not covered, he said he had a new exhaust, which is covered. But the exhaust does not include the flexi
Re: cat replacement
« Reply #7 on: 27 January 2010, 12:40:11 »
I reckon he's got it under warranty... 6 weeks old and already breaked :o :o :o
« Last Edit: 27 January 2010, 12:41:05 by Lazydocker »
Re: cat replacement
« Reply #8 on: 27 January 2010, 12:43:22 »
Depends, to me - 'new exhaust fitted' is cat back, not including the down pipe & flexi.
If he has had whole new exhaust, including down pipe, cat, flexi then yes it should be covered, and i should hope so as the downpipes are not cheap!  :o
bluehawk
Re: cat replacement
« Reply #9 on: 27 January 2010, 13:08:04 »
whoops mayube i should have made it clear complete exhaust from manifold all the way back, that why they are doing it
Re: cat replacement
« Reply #10 on: 27 January 2010, 13:12:43 »
Makes sense, to fail so quickly they are doing something wrong, there must have been too much stresss on the weld.
