Author Topic: PC Rebuild help required  (Read 1556 times)
redelitev6
Re: PC Rebuild help required
« Reply #15 on: 26 January 2010, 21:11:35 »
 :y DXP SP3 causes an issue with a particularly rubbish onboard audio chipset which nobody in their right mind should use.  - Why didn't someone say that in the first place!
« Reply #16 on: 26 January 2010, 21:16:29 »
Nobody asked the reason , so it was'nt mentioned.   ::)
Martin_1962
« Reply #17 on: 26 January 2010, 23:12:47 »
The higher spec P4s were stuffed by SP2
Your computer uses an Intel Pentium 4 or Intel Celeron D processor that is based on Prescott C-0 processor stepping.
And the Sp2 CDs didn't have the P4 patch on them.
The SP3 CD, and the SP1 CD have both vanished - I used the SP3 CD recently and it is not in my house.
All PCs have a genuine licence - none have been pirated.
Two PCs at work with genuine licences were taken out last year by WGA - the so called very rare false positive.
It took nearly a day to sort one of them.
Martin_1962
« Reply #18 on: 26 January 2010, 23:13:48 »
Never had any issues with SP3 - was on all work and my home PC
« Reply #19 on: 27 January 2010, 17:54:33 »
Not for the version you are trying to install, hence it not takking the key ;)
As for WGA failures, I suggest to look into how it works, and that will explain quite clearly why it is 100% accurate in the task it does (WGA checks that Windows is properly activated, thats all. If it fails, its an activation problem).
« Reply #20 on: 27 January 2010, 17:56:09 »
And you can slipstream SP3 onto any XP CD.  As long as the base CD is correct for what you want (eg Home/Pro/MCE and OEM/Retail/Volume)
