Author Topic: PC Rebuild help required  (Read 1582 times)
Martin_1962
« on: 25 January 2010, 22:42:42 »
P4 2.4 and all of our CDs are XP SP2 - which breaks P4s >:( >:(
I obtained an SP3 image, and used that - unfortunately it was not the normal MS image as I could not find one and MS only do the patches.
So problems are as follows
How do I change the licence number to the correct one for the PC as stamped on the CD booklet with the missing SP1 CD?
How do I fix the WinSXS stuff? WHat more is involved than copying the WinSXS off say my working home SP3 PC?
Thanks
Martin
Too much conflicting advice on the internet.
My boss tends to leave CDs on site.
Plomien
  • Swansea
    • Landrover Freelander TD4
Martin_1962
Re: PC Rebuild help required
« Reply #2 on: 25 January 2010, 22:52:18 »
Just the winsxs to sort now
« Reply #3 on: 25 January 2010, 22:53:41 »
PM sent ... be careful with that link above .. it can cause problems if your install version is not totally kosher .... read the write up first .. :)
Martin_1962
« Reply #4 on: 25 January 2010, 23:13:57 »
The same licence was used in the past on the same PC :y :y
« Reply #5 on: 26 January 2010, 20:35:34 »
Slipstream SP3 onto your correct XP CDs. Problem solved.
KillerWatt
« Reply #6 on: 26 January 2010, 20:43:04 »
Unless you have Realtek HD Audio hardware  ;)
Martin_1962
« Reply #7 on: 26 January 2010, 20:43:38 »
Seems like I need to install a few C++ libraries.
I think it was dot net 2.0 SP1 I needed
The current issue is that executables created on my home PC explode with silly errors.
Got a few things to try then I will have to give up
KillerWatt
« Reply #8 on: 26 January 2010, 20:43:54 »
What breaks exactly Martin?
« Reply #9 on: 26 January 2010, 20:49:09 »
Good point, well presented, though not a big issue, as surely nobody uses such poor hardware :P
KillerWatt
« Reply #10 on: 26 January 2010, 20:54:17 »
You'll be surprised at just how many use the onboard crap
« Reply #11 on: 26 January 2010, 20:59:33 »
Yeah, tell me about it ;).
redelitev6
« Reply #12 on: 26 January 2010, 21:01:22 »
 :-[ i haven't a clue on what you're talking about !!:'(
« Reply #13 on: 26 January 2010, 21:04:41 »
XP SP3 causes an issue with a particularly rubbish onboard audio chipset which nobody in their right mind should use.
Or, if we're talking about Martin Imber's post, he is trying to bypass Microsoft's anti piracy features, and failing miserably.
« Reply #14 on: 26 January 2010, 21:06:44 »
i run P4's which have had fresh installs of XP SP2 without issue  :-/ (although its a 1.4 not 2.4)
