Author Topic: Lucky escape.......  (Read 1115 times)
Debs.
Lucky escape.......
« on: 24 February 2010, 20:51:57 »
.....today: arrived at my sister`s house to hear a hissing sound, quite loud.....`checked under the bonnet as I thought it might have been a recurrence of the coolant leak I recently had.
No sign under the bonnet but the hiss continued, and got louder as I checked the off-side engine area, and then VERY loud as I bent down near the tyre.
Off with the wheel to find a 5 inch circumferential split in the inner edge of the tyre at the tread-sidewall corner.
Had just done 45 miles on the motorway at 70 mph speeds and had checked the tyre pressures before departing......I bought a lottery ticket; as clearly, it`s my lucky day. ;)
I had (recently) noticed a new vibration upon braking; when passing through 30-25 mph...I imagined a balance weight had come adrift, but with the spare fitted on the way home, there was no such vibration....note to self: "listen to the car, check the inner surfaces of tyres and don`t ignore new symptoms"
sexydaz
Re: Lucky escape.......
« Reply #1 on: 24 February 2010, 20:55:14 »
wot lottery numbers did yer choose....hang on while i get a pen and paper
lucky girl could have been nasty :-* :y
« Reply #2 on: 24 February 2010, 20:56:38 »
Shocking to say the least D, glad there was no dramatic event - you're quite right of course, the ability to listen and make sense of what you hear, is a blessing :y :y
« Last Edit: 24 February 2010, 20:57:44 by Zulu77 »
« Reply #3 on: 24 February 2010, 20:56:56 »
Bugga, glad nothing happended whislt you were on the move.   :y  I think that is also a message to the rest of us regards checking all the tyre and not just the pressures and tread depth.  :-[
P.s. can you PM me your lottery numbers please.   ::)
« Reply #4 on: 24 February 2010, 20:59:01 »
That was lucky Deb's, well spotted....... :y
« Reply #5 on: 24 February 2010, 21:01:02 »
I'm glad you're fine Debs......that's the important thing..... :y :y :-*
« Reply #6 on: 24 February 2010, 21:17:25 »
Nice one girl  :y :y :y  Glad it worked out the right way ... could have been nasty.
rob in gib
  • Plymouth
    • Jaguar S type 3.0
« Reply #7 on: 24 February 2010, 21:19:09 »
Debs so glad you are ok
let this be a lesson to all to check our tyres properly at least every two weeks including inner edges and pressures
on another note might be worth getting the suspension/steering checked as that tyre has worn badly on that inner edge HTH
Just chilling in the sun. I wish back in the rain like everybody else
jereboam
  • Suffolk
    • 1999 Omega Elite 3.0
« Reply #8 on: 24 February 2010, 21:26:52 »
Nasty!  I had something similar a few years back - stopped to recycle some bottles, headed off again to the main road (the A55 - you'll know that one) and got the impression something was wrong.  Unfortunately, I just reached the end of the slip road before it became clear where the problem was - the steering. :(
It wasn't until I found a safe place to stop that I found the chunk of unrecycled bottle in the nearside front tyre.  It b*ggered up the steering geometry horribly and Volvo never managed to get it sorted out - cost a lot of money, that did.  And just thinking about the 3 miles I had to drive on a dual carriageway with erratic steering gives me the willies even today. >:(
STMO999
« Reply #9 on: 24 February 2010, 21:27:03 »
That is so scary Debs. I don't think any of us would have picked that one up. Glad you're ok sweetheart. :-*
« Reply #10 on: 24 February 2010, 21:28:59 »
Glad you're ok Debs  :y :y
Amigo
  • Immingham N.E Lincs.
  • Be objective, be selective.
    • Passat & Cortina GXL
« Reply #11 on: 24 February 2010, 21:31:58 »
A stitch in time....... 8-)
Bent valve
« Reply #12 on: 24 February 2010, 21:34:32 »
Is that a directional tyre?
« Reply #13 on: 24 February 2010, 21:34:56 »
Lucky there Debs, if you win the lotto, don't forget OOF  :y
« Reply #14 on: 24 February 2010, 23:53:17 »
Looks like it might be time to get the camber set too. :y
