Author Topic: Not looking forward to this  (Read 1650 times)
« on: 01 March 2010, 09:14:01 »
Just had a call from the Father in Law... The culvert in their stream appears to be blocked and the water has risen to a very high level... Can I go and have a look :o :o :o
It's probably about 4' deep now and very cold but I can't have the "oldies" going in water that cold... ...Although they're well off ::) ::) ;D ;D
So... Time to find my swimming stuff :'( :'(
Plomien
  • Swansea
    • Landrover Freelander TD4
Re: Not looking forward to this
« Reply #1 on: 01 March 2010, 09:21:59 »
if you have a plumbers snake it might help shift it without having to go in :y
and if you do go in attach yourself securely with a rope
« Last Edit: 01 March 2010, 09:23:16 by Plomien »
Debs.
« Reply #2 on: 01 March 2010, 09:28:20 »
 :o No, No, no!.....Please do not go into the water; slimey-footing, suction and fast-currents may catch you unawares.....drain rods would be the only safe DIY choice.
Best to call the local council environmental dept. emergency No. and let them deal with it. ;)
« Reply #3 on: 01 March 2010, 16:22:57 »
All sorted! :y :y
Unfortunately the culvert is only about 8" across and was full of silt... It's actually more of a drainage ditch than a stream so not particularly fast flowing. Had to go in to get the right angle to get the drain rods through but was well secured :y :y
The unfortunate thing is that it was at "Critical Depth" and very cold, even through the waders :o :o Still.... Done now, just need to go and have another go at dredging the silt out when the level is more sociable ;) ;)
Debs, tried the council last time it happened and they weren't interested >:( >:( Came out about 3 days later, even though it was flooding across the road at about 6" depth! :o :o Was a mere 3" running across the road today and rapidly approaching the top of the bank inside the garden so needed doing ASAP. Level had dropped by about 3' when I checked it just before coming home... They felt they had to buy me lunch to compensate for my cold dipping :y :y
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
« Reply #4 on: 01 March 2010, 16:54:26 »
Next time you can borrow my dry suit with thermals, tis toasty warm in there...even in freezing water :y
« Reply #5 on: 01 March 2010, 16:57:04 »
Don't go in yourself. Can't you find an illigal immigrant to send in, they'll do anything for a few quid :D
« Reply #6 on: 01 March 2010, 16:57:45 »
Unfortunately they're all working the fields around here ::) ::) ;D ;D
« Reply #7 on: 01 March 2010, 17:00:10 »
Would have killed for it today ;D ;D
Unfortunately you're just a tad too far away ::) ::)
Water was very cold though :'( :'(
« Reply #8 on: 01 March 2010, 19:03:25 »
Glad that things went well all the same L  8-) :y :y
« Reply #9 on: 01 March 2010, 19:05:40 »
Lol, your meat and 2 vedge will be a similar size to the guys from Corsa sports in water that cold
Hannah Judes Dad
    • the misses round the bend
« Reply #10 on: 01 March 2010, 19:16:06 »
 ;D ;D ;D
« Reply #11 on: 01 March 2010, 22:26:13 »
Surly that is dependant on the starting point, if already a member of the Corsa Sports... :D :D :D
« Reply #12 on: 01 March 2010, 22:27:34 »
Put it this way... I had 3 Adams Apples and had to sit down to pee ::) ::) ;D ;D
« Reply #13 on: 01 March 2010, 22:28:31 »
Have you been peeking?? :D :D
Or has someone been telling tales :-X :-X
« Reply #14 on: 01 March 2010, 22:30:27 »
Something DLK said recently............. :D :D
