Sticky stuff
Started by Bo Bo, 04 April 2007, 11:05:03
Bo Bo
Anyone got any ideas how to rid of the "sticky stuff" left behind when a sticker is removed that won't damage the rear window heater?
Maplin do an aerosol of stuff called "sticky label remover". Haven't tried it on a rear window (I should, cos mine has a sticky bit) but I bet it would work. It just dissolves the glue.
Cheers,
Bo Bo
QuoteMaplin do an aerosol of stuff called "sticky label remover". Haven't tried it on a rear window (I should, cos mine has a sticky bit) but I bet it would work. It just dissolves the glue.
Cheers,
I have something similar, I'm just worried about the heater element....
Matchless
WD40 removes most adhesive residues but rear windows are a problem cos the adhesive gets baked in the sun. Dont rub too hard and only wipe along ther heater traces, not across them.
x25xe
I would use Meths.  I have done this before and it worked a treat.  Did not damage the heater element at all.  However, you will need to drive around for a while with the back windows open to get rid of the smell!
Yep meths is good but rub across rather than up and down
Auto Addict
QuoteYep meths is good but rub across rather than up and down
....as the actress said to the bishop.....
I like red cars
bob.dent
Bet you say exactly the same to the missus Pete  ;D ;D
Im not saying anything to the misses and she's not saying anything to me at the moment ;D
jamie
IPA (not the type that comes in a pint), or as already mentioned meths always works.
MV6 3.0L  XJ40 3.6L Sovereign (Galaxy Tdi130)
My non commercial Projects http://www.iecd.co.uk/ScratchPad/Projects/NonCon.htm
Some Pictures
http://www.iecd.co.uk/ScratchPad/temp/
