Pages: [1] 2 3  All   Go Down
Author Topic: Any mathematicians  (Read 2962 times)
STMO999
Any mathematicians
« on: 06 March 2010, 21:10:15 »
My lad asked me what the chances are of winning the lottery. I said about 14 million to one (I heard that somewhere). He said that, as we do two lines, that must be 7 million to one. Is that correct? Is two in fourteen million the same as one in seven million?
Re: Any mathematicians
« Reply #1 on: 06 March 2010, 21:11:45 »
yes
alunonhisown
« Reply #2 on: 06 March 2010, 21:12:26 »
Still 14 million to one, as you are doing seperate numbers on each line.
I think :y :y :y
« Reply #3 on: 06 March 2010, 21:14:44 »
There are 14million combinations....you have 2 in your hand and hence you have halved it to 7million...assuming your not stupid and have the same numbers on each line  ;D
STMO999
« Reply #4 on: 06 March 2010, 21:16:01 »
That's what I thought.....then I started to think.......I shouldn't think...... :D
Debs.
« Reply #5 on: 06 March 2010, 21:17:01 »
Predicated as:
6 balls
1-49 numbered
The odds become:
1/49 × 1/48 × 1/47 × 1/46 × 1/45 × 1/44 = 1 in 10,068,347,520
Bumbazor
  • Worksop
« Reply #6 on: 06 March 2010, 21:17:57 »
No, with another set of numbers it is another 14millionth of a certainty of matching the numbers drawn, and two 14millionths is one 7millionth.
I did all the possible six number draws, my chances of winning would be 1; a certainty (14 million 14millionths is of course 1).
Edit: for 14millionth, read what Debs has just posted instead, but the theory is still the same.
« Last Edit: 06 March 2010, 21:19:04 by Bumbazor »
STMO999
« Reply #7 on: 06 March 2010, 21:18:13 »
Predicated as:
6 balls
1-49 numbered
The odds become:
Thanks Debs, but I just won eff all. ;D :y
STMO999
« Reply #8 on: 06 March 2010, 21:21:17 »
Yes. That's logical. But, you know when you talk yourself out of things that you know must be true...... ;D
« Reply #9 on: 06 March 2010, 21:22:02 »
If you want to calculate the odds its as follows;
You have 6 numbers and there are 49 balls
First ball comes out
You now have 5 numbers and there are 48 balls
Seconds ball comes out
You now have 4 numbers and there are 47 balls
Third ball comes out
You now have 3 numbers and there are 46 balls
Fourth ball comes out
You now have 2 numbers and there are 45 balls
Fifth ball comes out
You now have 1 number and there are 44 balls
Last ball comes out
So the odds are calculated as
(49 x 48 x 47 x 46 x 45 x 44) / (6 x 5 x 4 x 3 x 2 x 1)
Which equals 13,983,816
Simples
« Reply #10 on: 06 March 2010, 21:23:21 »
Predicated as:
6 balls
1-49 numbered
The odds become:
A little errorette....its:
6/49 × 5/48 × 4/47 × 3/46 × 2/45 × 1/44
Because you have 6 numbers to start  :y
STMO999
« Reply #11 on: 06 March 2010, 21:23:28 »
Sorry Debs, but.......
The Chances Of Winning The UK National Lottery
•The Jackpot - 6 Numbers (Typical prize: £2 million)
6 numbers are drawn at random from the set of integers between 1 and 49, which means there are 49!/(6!*(49-6)!) combinations of numbers (the draw order doesn't matter). The means that the jackpot chance is 1 in 13,983,816 or approximately 1 in 14 million.
•5 Numbers + Bonus Number (Typical prize: £100,000)
You are still matching 6 numbers from the 1 to 49 set as above, but you can now do it in 6 different ways (by dropping each of the main numbers in turn), therefore the chance is 1 in 13,983,816/6, which works out as 1 in 2,330,636.
•5 Numbers (Typical prize: £1,500)
This is 42 times more likely than getting 5 numbers + the bonus number because, after the first six balls are drawn, there are 43 balls left and you can match 42 of these 43 balls without matching the bonus number. Therefore the chance is 1 in 2,330,636/42, which evaluates to 1 in 55,491.33333.
•4 Numbers (Typical prize: £65)
Firstly, let's take the case of the first 4 of your numbers matching and the last 2 not matching. In this single case (where each set of chances relies on the previous event occurring):
Chance that your 1st number matches a winning number is 1 in 49/6.
Chance that your 2nd number matches a winning number is 1 in 48/5.
Chance that your 3rd number matches a winning number is 1 in 47/4.
Chance that your 4th number matches a winning number is 1 in 46/3.
Chance that your 5th number doesn't match a winning number is 1 in 45/(45-2) [because there are still 2 unmatched winning numbers].
Chance that your 6th number doesn't match a winning number is 1 in 44/(44-2) [yes, still 2 unmatched winning numbers].
Now you need to accumulate all those chances by multiplying them together:
1 in (49/6)*(48/5)*(47/4)*(46/3)*(45/43)*(44/42) which is 1 in 15486.953. Now this is the chance for that single case occurring, but there are 15 combinations of matching 4 from 6 [6!/(4!*(6-4)!)], so you divide the answer by 15 to get 1 in 15486.953/15 or 1 in 1032.4.
•3 Numbers (Constant prize: £10)
Follow exactly the same scheme as the 4 match above to get these figures:
1 in (49/6)*(48/5)*(47/4)*(46/43)*(45/42)*(44/41) (which is 1 in 1133.119) for a single case. There are 20 combinations of 3 from 6 [6!/(3!*(6-3)!], so the chance of a 3 match is 1 in 1133.119/20 or 1 in 56.7.
The chance of you winning any of the above prizes is approximately 54 to 1 - it is reckoned an average of one million people per draw will win a prize.
Using some computer software I wrote, I calculated how many prizes would be won if all combinations of the 13,983,816 tickets were bought:
Category     Prizes        Chances
Jackpot           1    1 in 13,983,816
5+bonus           6    1 in  2,330,636
5-match         252    1 in     55,491.33
4-match      13,545    1 in      1,032.40
3-match     246,820    1 in         56.66
--------------------------------------------------------------------------------Total       260,624    1 in         53.66
STMO999
« Reply #12 on: 06 March 2010, 21:24:52 »
Spot on Mark!!!!!!!!
I hate you :P
« Reply #13 on: 06 March 2010, 21:25:41 »
I hate you :P
Why thank you kind sir.........
I spend to much of my life using maths!
Debs.
« Reply #14 on: 06 March 2010, 21:26:02 »
Predicated as:
6 balls
1-49 numbered
The odds become:
 ;D That`s Gentlemanly-speak for; you`re wrong! ;D
Pages: [1] 2 3  All   Go Up
