Author Topic: Computing Question  (Read 942 times)
Computing Question
« on: 12 March 2010, 10:25:16 »
Running Windows XP SP3. How easy is it to set up "virtual machines" ?? I have some software that will only work with IE6, so would like a VM with IE6 on it, and the rest of the system can get upgraded to IE8.
Never done any VM stuff before but willing to learn .. :)
Re: Computing Question
« Reply #1 on: 12 March 2010, 10:33:23 »
Plenty of free software that will do what you want. I use Innotek Virtualbox to keep a handful of different windows VMs on my XP machine at work for testing purposes. Several other ways to do it though.
« Reply #2 on: 12 March 2010, 12:06:55 »
If you have XP, and enough RAM (like shitloads, then add some more!), VMWare Server isn't too bad, and is free :D
Don't like the new web based interface of v2, but ho-hum.
Not sure if its just familarity, but I find VMWare's competitors (for Windows) a bit clunky.
« Reply #3 on: 12 March 2010, 17:52:15 »
Thanks both :) Downloaded and tried both ...
That VMServer is way too big and complicated for simple me    !!!
The Sun Virtualbox looks like it will do what I want, I've got it running with XP quite nicely ... now how do I get a programme from my existing hard drives into the virtual machine ??  It only lets me load via CD drives at the moment ... I suppose I could burn a disc but there must be an easier way ??
« Reply #4 on: 12 March 2010, 18:27:53 »
You have to install a driver on the virtual machine that makes the host machine's drive appear under an unused drive letter on the virtual machine IIRC.
Or, assuming you set up a network connection to the virtual machine, you could use a real windows CIFS file share.
