Author Topic: Toilet fittings  (Read 1802 times)
Re: Toilet fittings
« Reply #15 on: 15 March 2010, 13:59:27 »
......save the seat fouling on the handle......
 :o Eeeeewwwwwwww!.........`dirty boy! ;D
how did I know someone would pick up on that  ;D ;D ;D
Re: Toilet fittings
« Reply #16 on: 15 March 2010, 14:14:30 »
ahh ok, didnt look like a flapper style,
b&q and screwfix are next to each other, so ill have a look at em all  :y
Yes, its a system that has a piston type setup with a rubber seal....so press short flush and it flushes for as long as you press it, press long flush and it flushes a set volume which is set via the float which you can see around the central column.
Re: Toilet fittings
« Reply #17 on: 15 March 2010, 14:17:11 »
cool, sounds good, and a good price, think thats decision made.
I gather some of the flapper type are sensitive to dirt in the tank, are they cistern block compatible do you know?
Welung666
Re: Toilet fittings
« Reply #18 on: 15 March 2010, 14:19:22 »
We use a block in our without probs (not a bloo btw, I can't pee into funny coloured water!).
Re: Toilet fittings
« Reply #19 on: 15 March 2010, 14:56:54 »
The type I listed will be ebtter as it has some additional surround to keep the blcoks away from the valve seat.....a standard flapper would be more prone to issues I would say!
Re: Toilet fittings
« Reply #20 on: 15 March 2010, 16:04:44 »
Went for that design as it seemed more robust and weighty, plus had a 10 year guarantee, and I didnt like the square button of the fluidmaster type.  your link looked much neater  :y
Cheers
STMO999
Re: Toilet fittings
« Reply #21 on: 15 March 2010, 17:09:16 »
Cheers
Save you blowing it apart. ;D ;D
Re: Toilet fittings
« Reply #22 on: 15 March 2010, 18:06:56 »
What size is the "push button" thingy ??? The hole where the present handle spindle goes through don't look very big to me ...   :-/ :-/ :-/ :-/
Re: Toilet fittings
« Reply #23 on: 15 March 2010, 18:37:35 »
the push button is about 1.25" diameter, will stick out about 1"
the bit that goes through the hole is about 1/2" so shouldnt be a problem
guess it would 'flush' mount (  ;D ;D ;D ) on some of the newer cisterns
unlucky mark mv6
  • tipton,west mids
Re: Toilet fittings
« Reply #24 on: 15 March 2010, 19:04:23 »
Torbecks are very good,nice and silent. :y
