Author Topic: Sky TV Link  (Read 1450 times)
alfie
  • Gwent
    • Mondeo Ghia estate tdci
Sky TV Link
« on: 15 March 2010, 20:39:43 »
Hi everyone,please can someone help me out here,unpluged the tv last weekend to take with us in the van,reconnected last night upon return home.
Retuned but ,no little red light on the link,hence no remote service thought to myself u/s link so replaced with a new replacement still no good.
Any help out there?.
Alfie.
PS my lucks buggered this month.
Re: Sky TV Link
« Reply #1 on: 15 March 2010, 20:43:01 »
When you say link do you mean the 2nd remote control.  if thats the case the magic eye needs to be on the 2nd output on the back of the sky box.
alfie
  • Gwent
Re: Sky TV Link
« Reply #2 on: 15 March 2010, 20:51:24 »
Hi,yes all that was all up and running and perfect.until I unplugged the set.
When I retuned upon retune home,no light shows on the link/magic eye,so no remote function on the handset.
Alfie.
Welung666
Re: Sky TV Link
« Reply #3 on: 15 March 2010, 20:55:00 »
Somewhere in the settings menu is the option to turn the power on or off the the 2nd connection/link eye.
Re: Sky TV Link
« Reply #4 on: 16 March 2010, 01:44:17 »
you need secret engineers menu to check rf outlet power supply is set to on. Should not have changed to off though.
Press services, select settings, press 01 select, or on mine scroll to health first or it wont work. Then scroll to rf outlets, select rf outlet power supply and press right arrow to turn on, then green button to save setting. Sky button to exit.
If this setting is off you still get picture on rf outlet 2 but digi eye no work.
If you have a distribution box on rf out 2 it will need to loop that out to work, but i guess thats not been touched if you have one.
Also worth a google, or a call to sky.
Re: Sky TV Link
« Reply #5 on: 16 March 2010, 01:49:48 »
You'll need to do this from the main tv now obviously, on rf  out 1...
...and as i've now turned mine off to check, i've now got to get out of bed and go down stairs to to turn the bugger back on again. :D :D ;D ;D ::)
alfie
  • Gwent
Re: Sky TV Link
« Reply #6 on: 16 March 2010, 07:05:22 »
Thanks Chris,I,ve checked out all the settings and suggestions.The only other thing suspect is the leads,the wife is the one who disconnctedthe tv she might have pulled to hard on the coax leads.
Alfie.
alfie
  • Gwent
Re: Sky TV Link
« Reply #7 on: 16 March 2010, 18:19:08 »
All sorted now,it was the fly leads.Replaced them,now 100%.
Alfie.
STMO999
Re: Sky TV Link
« Reply #8 on: 16 March 2010, 18:20:26 »
Alfie.
Replace the wife as well :y
alfie
  • Gwent
Re: Sky TV Link
« Reply #9 on: 17 March 2010, 14:30:10 »
To expensive
