Project TB2 - Update 3
Started by TheBoy, 06 April 2007, 18:02:58
Not much done yet. Still overheating or overpressurising.
Current thinking is that it may be overheating, and dash gauge is wrong. So I've sent tunnie down scrappy to find a coolant sensor so I can Tech2 the ECU to get coolant temp.
While he is down the scrappy, I've been fixing odds and ends inside the car.  Had to put in another climate unit, as the drivers side display was fubar. Fixed up some other stuff around that area as will.
Flushed the coolant through yet again, its all coming out very clean now.
Changed the backbox on the Rover as well, as thats being MOT'd on Tuesday.
What're you doing about the rad?
QuoteWhat're you doing about the rad?
Reluctant to change it unless I can prove its at fault...
Auto Addict
I think the rad is a red herring. Carry on with your other thoughts.
I like red cars
Wonder if anyone has a spare you could just try....
QuoteWonder if anyone has a spare you could just try....
Alas, unlikely. Tractors are fairly rare anyway...
Markie
coolant sensor / thermostat / and hard pipes -air block would be my line of thought first of all.
Quotecoolant sensor / thermostat / and hard pipes -air block would be my line of thought first of all.
Flushed a number of times, and its supposed to be self bleeding, so don't think its airlock.
Stat replaced, old one had been drilled.
And it seems the coolant sensor is not the fault with the coolant sensor  >:(, must be somthing in the loom  >:(. Or ECU  >:(
And the intercooler fan is seized. And the idiot who designed the cover is a ******* ******  >:(  >:(  >:(
And one of the bolts holding the front plastic cover to the intercooler is seized.
Bloody tractors  >:(
what did you say the temp sensor was reading again? -40 or something silly?!?!!?!!
You might be right on the over fueling with that.... so if its constantly giving it more fuel would account for overheating. Plus the nakered intercooler, and fans not kicking in...
I think it's all still linking back to that sensor.... or the loom leading to that...
Quotewhat did you say the temp sensor was reading again? -40 or something silly?!?!!?!!
It knows that reading is rubbish, so substitutes more sensible values...  ...possible fuelling incorrectly, not convinced doing so to overheat though  :-/
Intercooler fan isn't there to cool the system ;)  (its there to cool turbo'd air, as cold air more dense, so can get more in cylinders, hence more power)
Omegatoy
HOhO Got exactly the same faults on the other estate!!! except it doesent blow the water out, just gets hotter and hotter goes up to 98 or so then i chickened out! bridges the leccly fans didnt seem to help, found out the first speed onn the fans comes in at 95, second speed full power isnst designed to come on till about the 100? cant be right surely? anyway started to look outside the box so to sspeak and lo and behold think i have found it but!! wont know till tomorrow when i fit the needed part and try it!! however if its the same fault on yours mate its a bastard to find!!!
Omegatoy
QuoteHOhO Got exactly the same faults on the other estate!!! except it doesent blow the water out, just gets hotter and hotter goes up to 98 or so then i chickened out! bridges the leccly fans didnt seem to help, found out the first speed onn the fans comes in at 95, second speed full power isnst designed to come on till about the 100? cant be right surely? anyway started to look outside the box so to sspeak and lo and behold think i have found it but!! wont know till tomorrow when i fit the needed part and try it!! however if its the same fault on yours mate its a bastard to find!!!
Omegatoy
Tell you what was a bastard of job, getting that engine temp sensor!!.... managed to do it again on TB's JCB without removing the intake manifold!
Omegatoy
Please, please, please let on....  ....PM if you want it kept private!
Omegatoy
Well, technically, you didn't get the old one out. Yet.
