Author Topic: Tool Description  (Read 1794 times)
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
Tool Description
« on: 21 March 2010, 16:55:27 »
I'm sure that many of us will recognise these tools. :y :y :y
DRILL PRESS: A tall upright machine useful for suddenly snatching flat
metal bar stock out of your hands so that it smacks you in the chest and
flings your beer across the room, denting the freshly-painted project
which you had carefully set in the corner where nothing could get to it.
WIRE WHEEL: Cleans paint off bolts and then throws them somewhere under
the workbench with the speed of light . Also removes fingerprints and
hard-earned calluses from fingers in about the time it takes you to say,
'Oh sh--!'
SKILL SAW: A portable cutting tool used to make studs too short.
PLIERS: Used to round off bolt heads. Sometimes used in the creation of
blood-blisters.
BELT SANDER: An electric sanding tool commonly used to convert minor
touch-up jobs into major refinishing jobs.
HACKSAW: One of a family of cutting tools built on the Ouija board
principle... It transforms human energy into a crooked, unpredictable
motion, and the more you attempt to influence its course, the more
dismal your future becomes.
VISE-GRIPS: Generally used after pliers to completely round off bolt
heads. If nothing else is available, they can also be used to transfer
intense welding heat to the palm of your hand.
OXY-ACETYLENE TORCH: Used almost entirely for igniting various flammable
objects in your shop on fire. Also handy for igniting the grease inside
the wheel hub out of which you want to remove a bearing race.
TABLE SAW: A large stationary power tool commonly used to launch wood
projectiles for testing wall integrity..
HYDRAULIC FLOOR JACK: Used for lowering an automobile to the ground
after you have installed your new brake shoes, trapping the jack handle
firmly under the bumper..
BAND SAW: A large stationary power saw primarily used by most shops to
cut good aluminum sheet into smaller pieces that more easily fit into
the trash can after you cut on the inside of the line instead of the
outside edge.
TWO-TON ENGINE HOIST: A tool for testing the maximum tensile strength of
everything you forgot to disconnect..
PHILLIPS SCREWDRIVER: Normally used to stab the vacuum seals under lids
or for opening old-style paper-and-tin oil cans and splashing oil on
your shirt; but can also be used, as the name implies, to strip out
Phillips screw heads.
STRAIGHT SCREWDRIVER: A tool for opening paint cans. Sometimes used to
convert common slotted screws into non-removable screws and butchering
your palms.
PRY BAR: A tool used to crumple the metal surrounding that clip or
bracket you needed to remove in order to replace a 50 cent part.
HOSE CUTTER: A tool used to make hoses too short.
HAMMER: Originally employed as a weapon of war, the hammer nowadays is
used as a divining rod to locate the most expensive parts
adjacent the object we are trying to hit.
UTILITY KNIFE: Used to open and slice through the contents of cardboard
cartons delivered to your front door; works particularly well on
contents such as seats, vinyl records, liquids in plastic bottles,
collector magazines, refund checks, and rubber or plastic parts.
Especially useful for slicing work clothes, but only while in use.
SON-OF-A-BITCH TOOL: (A personal favorite!!) Any handy tool that you
grab and throw across the garage while yelling 'Son of a BITCH!' at the
top of your lungs. It is also invariably the next tool that you
will need.
Re: Tool Description
« Reply #1 on: 21 March 2010, 17:09:23 »
  ;D ;D ;D ;D ;D:y
Debs.
« Reply #2 on: 21 March 2010, 17:23:31 »
 ;D You`ve been in my workshop! ;)
Richie London
  • heathrow
« Reply #3 on: 21 March 2010, 17:25:08 »
BENCH PLANER: for running a few mm off a piec of wood to make it smaller in width. and also taking the tips of your fingers off while planing down sash beads.  :'( :'( :-[ :-[ ;D ;D
splott
  • Bebington, The Wirral
  • Veccy with a Miggy engine..............
    • Vectra GSI 3.2 v6
« Reply #4 on: 21 March 2010, 17:26:51 »
I've got every one of those tools ;D ;D ;D ;D :y
Thank you for reading this. I’ve officially wasted your time!
Richie London
  • heathrow
« Reply #5 on: 21 March 2010, 17:31:30 »
40mm oval nails, they come in handy if you want to nail down central heating pipes when fixing down loose floorboards. and give the wife a shower if she stands under the light in the kitchen   ;)
Shackeng
  • Ramsbury
« Reply #6 on: 21 March 2010, 18:25:57 »
Were you watching? Also, 2" screws for screwing gas pipes to the wall, prior to the explosion, (I made the explosion up!) ::) ::) ::) 8-) 8-) 8-) :y :y :y
threppence
  • Leeds
« Reply #7 on: 21 March 2010, 20:07:24 »
 ;D ;D ;D ;D
The Oil Stone - The perfect accessory  to transform slightly blunt chisels into handy paint tin openers.
The Bare-Ars*ed Saw - As in it's so blunt you could ride bare ars*ed to York on it.
When INJUSTICE becomes LAW,
RESISTANCE becomes DUTY
jonnycool
  • Merthyr Tydfil, S. Wales
  • We shag 'em, you eat 'em
« Reply #8 on: 21 March 2010, 21:11:35 »
 ;D ;D ;D
« Reply #9 on: 21 March 2010, 22:24:59 »
 ;D ;D ;D ;D ;D ;D
You forgot SAMMY ::) ::) ;) ;)
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #10 on: 22 March 2010, 10:55:54 »
 :D ;D :D ;D :D ;D
