Project Elite - Request for help
Started by JamesV6CDX, 06 April 2007, 17:40:10
MaxV6
Ahhh.... and is the earlier one still available chaps??
perhaps that's contributory to there beinga remaining small leak and coolant weirdness on mine???   (I do hope not.... but ....   )
sorry James, it seems I have the later "piss useless piece of crap that breaks things"  and your transfer pipe o rings...
Still at £1.82 for the lot, it's not a major disaster, but it does screw you up for finishing the job by monday night....
Max
sounds2k
.... so you might be needing one of these as well when it does  :'(
QuoteAhhh.... and is the earlier one still available chaps??
Max
Ahh well... sh*te happens.... I do appreciate your efforts Max......
As Mark says, maybe some sealant around the old stat will be OK
In terms of your Stat housing... I am prepared to bet my right leg on the fact that it's not leaking after the treatment I gave it ;) ..
MaxV6
take some freindly advice form an older chap.
bet the left leg...    you don't need it in an Elitie auto. !
Quotetake some freindly advice form an older chap.
;D ;D ;D ;D
Max, I'm going to "improvise" on the stat seal, but I could still do with the transfer pipe rings..
Any chance of me popping up tonight, after dark? (so I can tinker with the other bits in daylight)..
Cheers :)
James
Sorry, change of plan.
Girlfriend doesn't want me to go
I'll have to sort something out another time :(
MaxV6
what ever's easiest mate....  politically and practically.....   ;)
where are you at present, Cheltenham??    if so, i don;t mind popping them over tonight.
