Project Elite - Request for help
Started by JamesV6CDX, 06 April 2007, 17:40:10
This is a long shot, but I'm going to be held up over easter weekend due to the lack of a thermostat seal, and the 2 o rings for the front coolant transfer pipe
Does anyone have these components, that I could use and then replace?
MaxV6
I'm afraid AFAIK i only have the ones you put on the car mate, although i had a feeling there were 2 spare o rings...  but I don;t have them if there were...   I just looked ..
however I'd be happy to see if any of our local dealers have them and are open tomorrow morning.
Max
Most dealers are open tomorrow morning...
QuoteI'm afraid AFAIK i only have the ones you put on the car mate, although i had a feeling there were 2 spare o rings...  but I don;t have them if there were...   I just looked ..
Max
you're a star... if you'd be so good as to make a call, I'd be eternally grateful :)
I have the two for the transfer pipe......but not for the stat to block seal although the grey sealent for the oil cooler works well here in conjunction with the old seal....
sounds2k
I have all of them ... 2 x P/N 9129999 (transfer pipe seals) and 1 x P/N 9128363 (stat to block) ... but I'm in Kent  :-/
part numbers should help tho  :y
MaxV6
QuoteI have all of them ... 2 x P/N 9129999 (transfer pipe seals) and 1 x P/N 9128363 (stat to block) ... but I'm in Kent  :-/
Indeed, I'll call the dealers first thing, I tried this afternoon, but they was all skiving off......   :(
Max
MaxV6
bellingers of grove/wantage have them in stock.  I'm off to get them now.
Max
Beware the stat to block O ring....they generally only supply the later item and if used with a standard stat housing....it breaks the housing!
MaxV6
I Have them James....  (based on part numbers supplied above)   I can bring them over tonight, I have to drop my daughter off at her grans (near Chipping Norton)  at 5 pm or I'd head over now....
no Sat Nav as i'm in the 106 this weekend , the Meega is at the garage having all it's bits done for MOT and a full service (only thing they're not doing is the leak...  )
So I'll need clear directions....
Max
Hi max,
You're a star
I'm actually not home until the morning now - I guess I'll have to pop up and get them from you?
QuoteBeware the stat to block O ring....they generally only supply the later item and if used with a standard stat housing....it breaks the housing!
Do you know what the part numbers are for old and new? Is the part number that max got (as above) for the older type O ring?
MaxV6
whatever's best for you James... I'm easy...  quite happy to drop them over, or for you to pick them up...   the only real difference being that you already know how to find our place.
Max
sounds2k
EPC shows the old stat to block P/N as 90410900 - superseded by P/N 9128363 ...
And the later seal is almost guaranteed to break the stat............been there, done that....bought the T-shirt.
