An Engine Without Oil....
Started by Markie, 08 April 2007, 10:19:47
Markie
How long can i leave an engine with no oil in it.
Its that Vectra...removed sump / filter etc etc to drain the oil out ( the good news is its just good blackk used oil with no contamination)
I've now come inside to get "work ready"  >:( and run out of time replacing sump / filter etc and therefore not filled its new oil.
Now The car is garaged and wont be started obviously... ( not even got a battery in it)
Can the second part of the job wait til next weekend....or should i be doing it at 11pm tonight  :-/Can siezed engines and oil starvation effects happen THAT quick?
hotel21
When was the engine last run?  If it was ages ago, outside chance of a problem but if ran recently (last week or two) should be OK as long as the garage is dry.  If theres any trace of damp then it will find a dry bit and create surface rust.
If its going to be overhauled anyway, then all should be sound..
HtH
B
Markie
QuoteWhen was the engine last run?  If it was ages ago, outside chance of a problem but if ran recently (last week or two) should be OK as long as the garage is dry.  If theres any trace of damp then it will find a dry bit and create surface rust.
HtH
B
last ran errrrrrr 4 months ago.
Oil cooler failure etc etc stopped it. Having service etc by me now oil cooler / radiator / water pump / thermostat/ hoses are replaced.
Garage is a real warm dry one  :y
Markie
QuoteIt will be fine....
:y thanks Mark.......guess we will know for sure late on this sunday... :-/
PxMetro
I remember many years ago (late 70's) working in a garage as an apprentice motor mechanic, fresh out of school, trying to fathom what these strange knocking noises were coming from the engine of a car I had just serviced. It took a while before someone asked the obvious question "Did you remember to re-fill the engine with oil"
Oh Dear! :-[ :-[
Chopsdad
Oh I'm so dissapointed, I thought this was going to be another great Oil Thread  ;D
Markie
QuoteOh I'm so dissapointed, I thought this was going to be another great Oil Thread  ;D
well actually i was wondering what to put in it when i get round to filing it...any thoughts :D
DaveL
....insperation and desperation. ;D ;D ;D ;D
8-)
DaveL
