Jobs done this (long) weekend
Started by Markjay, 09 April 2007, 20:22:10
Markjay
Replaced front wheel bearings, brake discs & pads
Camcover leak sorted on driver-side (the easy one...), breather box cleaned.
Errrr... that's it.  :)
Alas, no more Omegas....
Timbuk
Taxi_Driver
Markie
...and an excellent " how to guide"  :y
theolodian
Are the front wheelbearings service items or replace only?
oh yeah, well done  :)
[move]Trains may have been invented here, but public transport is a foreign concept![/move]
Markjay
Quote...and an excellent " how to guide"  :y
Just a reminder to anyone considering changing the front bearings - it is only one single nut, if you have the right tool to remove it and the right tool to fasten it then there really isn't much too it...
Markjay
#6
QuoteAre the front wheelbearings service items or replace only?
1. Replace only, they are non-adjustable (e.g. you can't just tighten then a bit to eliminate play etc)
2. They come with the wheel hub (the bit that the disc brake bolts onto)
3. they are around £70 each side on TC  :(
4. the good news is that they normally go... I must have been unlucky.
Quote3. they are around £70 each side on TC  :(
Pattern parts are cheaper....
theolodian
OK, cheers.  If the pavement surface and speed are just so I get a wobble/rattle in the OSF that feels like a wheel bearing, ball joint, etc.  However I have new wishbones and the steering links are all solid.  Only other possibility is droplink I guess.
Markjay
A bearing problem should come up as play when rocking the wheel with the car jacked-up. Incidentally, mine was only rocking side-to-side, but nor top-to-bottom. The way to confirm apparently is to have someone fully apply the brakes and then check again for play - if the play is gone, then it's the wheel bearing, if the play is still there then it is another suspension component.
Markie
are they recommended? or a steer clear like exhausts?
Markjay
I did look for pattern, but the only seller that had them for real cheap (£40) only had one unit, and I needed two... the other ones I found on eBay were marginally cheaper e.g. around £60 so I decided to stick with Vx. I didn't try the likes of Autovaux though....
Markjay
The Vx ones I bought are made by Toyo Japan. I know that SKF makes Omega front bearing (with the Hub), and they are pretty good, but I couldn't find them anywhere...
I have a pattern on the MV6.... .....time will tell....
Markjay
How much were they?
