Wasted Spark
Started by Markie, 13 April 2007, 18:07:32
Markie
Whats all that about then  :o
New phrase to me can anyone give me a nice simple explanation  :-[
At work and it just popped into my head !
sounds2k
each coil on the DIS pack connects to two spark plugs. It fires twice - so one cylinder will be full of air/fuel mixture and go pop, the other will be on the exhaust stroke and firing the spark plug will do nowt. So the firing of the latter is a waste = wasted spark  :y
Markie
Quoteeach coil on the DIS pack connects to two spark plugs. It fires twice - so one cylinder will be full of air/fuel mixture and go pop, the other will be on the exhaust stroke and firing the spark plug will do nowt. So the firing of the latter is a waste = wasted spark  :y
Marvellous  :D :y
Learn something new every day  ;)
Bo Bo
Blimey, I actually understand that  :o
iggy21uk
QuoteBlimey, I actually understand that  :o
Does that make you a bright spark ?  ;D ::)
[color=red][size=10]Opelscanner Can owner / Cam lock kit owner [/size] [/color]
Marvellous  :D :y
The later K series are same - the ones with the 2 coil packs on top of the plugs...
Markie
Marvellous  :D :y
yeah would explain the term wasted spark or dizzy engined t series too. Coil or distributer based  :y
sounds2k
... as opposed to a drugged-up electrician ... who would be a wasted sparky  :P
... I'll get me coat  :-[
