Author Topic: pc question can i split a vga signal?  (Read 1200 times)
doog
  • Alloa Central Scotland
« on: 22 April 2010, 09:43:40 »
I need to be able to feed 2 tv's from the vga output of my laptop
both tvs are different brands  and i wondered if there is any device that would allow me to feed both screens from a single vga output from my laptop?
Doug
me at kick boxing
Re: pc question can i split a vga signal?
« Reply #1 on: 22 April 2010, 09:46:07 »
vga multipliers must be your answer imo
http://www.byterunner.com/ifsm/vga-multipliers.shtml
Xplicit 2.0
  • Dorset, UK
« Reply #2 on: 22 April 2010, 09:47:21 »
basicly yes u can :y :y :-X :-X :D ;D
« Reply #3 on: 22 April 2010, 09:49:20 »
Yep, you need a splitter with a distribution amplifier for decent results. Something like this: http://www.dabs.com/products/startech-com-vga-video-splitter---distribution-amplifier-2-port-4H1F.html
Note - not a recommendation, just the first link google spat out.
Make sure it's not just a passive splitter as these will not produce satisfactory results. (an amplified box will need a power supply, for a start)
« Reply #4 on: 22 April 2010, 09:50:08 »
You need a proper splitter device (as per the link above) or the terminations will all be wrong and cause reflections in the signal path.
« Reply #5 on: 22 April 2010, 10:08:33 »
do want a mirrored display or separate outputs?
« Reply #6 on: 22 April 2010, 10:10:55 »
I have assumed both TVs have 15 pin analogue SVGA inputs, of course. If not, it gets a little more tricky.
Chris_H
  • E London/Essex UK
    • Jag XF Portfolio S 3.0D
« Reply #7 on: 22 April 2010, 10:13:02 »
..and a dull picture.
The links shown above look OK but I got caught out on a cheapo composite video one that I had to modify extensively because it just was an appalling design.
Kramer are good if not the cheapest.
First Vauxhall - PABX Cresta; Previous, previous Vauxhall - 3.0 12v Senator CD; Previous Vauxhall Omega Elite 3.0V6 Saloon Auto
doog
« Reply #8 on: 22 April 2010, 15:50:34 »
Thanks for the input guys
i will provide a little more info
I am starting work in a new venue in 2 weeks one of the nights will involve karaoke and another night will be a pub quiz  . Usually i connect my laptop to 1 large screen  but this place has 4 tvs dotted around the bar  and i want to be able to display on all of them
Im off for a google  on vga splitters   :y
Doug
me at kick boxing
Chris_H
  • E London/Essex UK
« Reply #9 on: 22 April 2010, 16:09:59 »
Doug
Good VGA cables are quite bulky and expensive but worth it over any but the shortest run.
« Reply #10 on: 22 April 2010, 20:52:24 »
Doug
Try cem's link, slightly modified - http://www.byterunner.com/ifsm/vga-video-splitters.shtml
