Project Elite - Gearbox prob fixed (almost!!!)
Started by JamesV6CDX, 13 April 2007, 20:45:43
Ok, jacked it up, had a look under the car. Saw a big 4 pin plug disconnected ... big smile. Plug it in.. fire it up.. all working. Winter mode works, sports mode works.
Go for a quick run.. do a mile or so.. WOW.. drives really well through all the gears. Then suddenly... bleh... same problem. Into limp mode.
Drive it home - look underneith again. Connector is secure. Hmm. Take it out, Put it back, make sure it's home. Fire up again, and no sports/winter mode.
Take it off AGAIN .. look at it.. and in the plug there are 4 metal pins, that make contact with the plug on the box. One of them has broken off, hence not making a decent connection.
Guess I can nick the plug off the 2.5 and just join the wires. Bit concerned that there may still be some broken off pin in the other end.. but it's NOT accessible to look at (all done by feel!)
At least I'm somewhere close....
Admin
Good  to hear it was nothing serious. :)
To make access easier simply lower the gearbox...
The Administrator.
theolodian
QuoteGood  to hear it was nothing serious. :)
Simply he says!  :o
Well, I guess it would be for James.  ;)
[move]Trains may have been invented here, but public transport is a foreign concept![/move]
Simply he says!  :o
Remember what admins here say is 'Easy' is  :o :o :o :o to most of us! And bloody hard  ;)  ;D
Lowering the box wouldn't be too hard... however I doubt I'll need to...
I'm going to get Markie the electrician to put a new connector on for me  :y
Martin_1962
theolodian
QuoteLowering the box wouldn't be too hard... however I doubt I'll need to...
Just make sure the pin isn't still in the socket.  Hopefully a mirror will do the trick.
QuoteGood news! :y :D
So when am I going to see it?
Unfortunately not tomorrow... no MOT yet...
All being well, if work don't call me in (I'm on call)... then I should be Ok to pop up the road and lend a hand, as per PM... but I can never commit to it when on call :(
Martin_1962
Damn - looking forwards to seeing bargain Elite! ;D :(
Anyway if you turn up so much the better - I'll have to get the scuttle off anyway.
Doing town this morning, got your mobile - I'll PM mine
