New to this what does this arial do
Started by Ernie, 13 April 2007, 10:46:15
Ernie
As above is this for the radio or is it for some thing else ?
Bit of a blonde thing to ask i know but new to omega's.
Thank you.
The FM radio antenna is built into the heated rear screen. I presume that is a mobile phone antenna.
There is an extra antenna connection behind the driver's kick panel which seems to be routed in that direction.
ClarCE
Could it be an aerial for built in sat nav?
So Far - :: Re-Finished Elite Wheels :: Black Leather Interior :: 3.0 Cams :: Chipped (REMOVED, EBAY SHI*E) :: Facelift Skirts ::
To Do   - :: Facelift Rear Bumper, Door Mouldings :: Irsmsher Front Air Da
Martin_1962
Ernie
I didnt think it was for the radio but thought i would ask thank you only had the car 2 weeks now.
It's the phone aerial, aerials on the later models had a bigger base that housed the sat nav antenna and the traffic master antenna is usually tucked behind the dashboard (On the vectra it's just two wires taped to the glovebox).
HTH
Yes, is mobile phone.  SatNav lives on dash (early ones) or at base of mobile phone ariels (later). TM is all around the unit.
Dean
I have one of these on my mini facelift elite, if the opinion is that its a phone antenna i will have to try and find where the lead terminates, maybe i can fit a car kit and use the antenna?
anyone any ideas where it will be on my mini facelift?
Free Traffic law advice  - Just PM or see the sticky thread in General Chat ! http://www.omegaowners.com/forum/YaBB.pl?num=1177278724 - no liability accepted
Markjay
Indeed, mobile phone aerial, but only 900Hz NOT 1800Hz,  i.e. good for O2 and Vodafone but NOT Orange or T-Mobile/Virgin.
There is also a loom that terminates somehere in the central console area.
Alas, no more Omegas....
hotel21
If you remove the sound deadening kick panel in the passenger footwell and have a rake around with a good torch you should find it.  Black coax type lead with a silver metal quarter turn connector (at least, thats what I found on my 98 minilift)
HtH
B
Dean
Typical I have an orange Phone..will it not work at all?  :'(
Exactly as Hotel21 says...
You need to extend to your kit.  Though most modern kits do not use an external antenna anyway, using the one in the handset instead...
Chopsdad
#12
Not such a stupid question Ernie - I thought it was for radio, and I've had the car 4 years  :-[
Taxi_Driver
QuoteNot such a stupid question Ernie - I thought it was for radio, and I've had the car 4 years  :-[
It is on facelift estates, well both really, radio and phone  :y
Not sure about prefacelifts but would assume the same.
