Author Topic: Leisure battery.  (Read 2076 times)
Re: Leisure battery.
« Reply #15 on: 29 April 2010, 21:54:36 »
I'm pretty.....   Ok i'm pretty sure it charges automatically when hooked up to 240 volt or the genny.  .....
My power supply unit needs to be switched on for my battery to charge when on hook up :-/
most vans now the charger is wired to the mcb so when hooked up its on straight away older types had a charger which you could manually switch or a designated switch on the control panel
..... and Guy's caravan is an 'older type' of caravan  ;)  :y  :y
sexydaz
« Reply #16 on: 29 April 2010, 21:56:32 »
what van yer got andy
« Reply #17 on: 29 April 2010, 21:57:29 »
2002 Lunar Delta 520/2 (single axle)  :y
« Last Edit: 29 April 2010, 21:58:57 by Andy_B »
sexydaz
« Reply #18 on: 29 April 2010, 22:04:15 »
nice vans them,big and light.of all the vans i see its hard to remember them all its just another van on my bay but the lunars back then that ive seen was a bit 50/50 some had a few damp probs and some were bone dry if you have a dry one you have a nice van :y
sexydaz
« Reply #19 on: 29 April 2010, 22:07:25 »
what was it now..EB and EW for end washroom and end bedroom..your mig will play with that
« Reply #20 on: 29 April 2010, 22:14:25 »
That's not a very good advert for the Omega..... :D :D :D
« Reply #21 on: 29 April 2010, 22:24:25 »
Yes, end washroom, it's great with just 2 of us in it.  :y
No damp problems, I had a slight problem last year with the offside awning rail becoming slightly detached at the back end on the end panel. Sorted now though.
« Last Edit: 29 April 2010, 22:25:52 by Andy_B »
« Reply #22 on: 29 April 2010, 22:27:34 »
It's not is it.  :( It was the start of my rad leak problem, we came back from Devon with the aid of a can of radweld.  ::)
